Cornet2 no heater, help!
0 Members and 1 Guest are viewing this topic. Read 5295 times.
binar
« on: 11 Dec 2014, 07:02 pm »
 :o
Hi all, I grabbed one of the Cornet 2 boards a while ago because I heard
they were going to be discontinued and I didn't want to miss out on this
tremendously renowned kit phono stage. I've built a Clarinet board that
I bought at the same time with Jupiter copper foils and Kiwames and it
sounds really excellent.
I completed the Cornet 2 last week and was bringing it up on a variac.
LED turned green and nothing smoked so I hooked it up to my rig. No
sound. I then noticed no filaments in the signal tubes were lit. I pulled
the plug and have been unable to return to the issue since.
I may be missing some larger issue but all I can think to do is to look
at the H+ circuit testing values for each device until I get to the socket.
Does this problem ring a bell with any of the old pros around here? Can
anyone offer any advice to a noob?
Many thanks!
hagtech
    • http://www.hagtech.com
Re: Cornet2 no heater, help!
« Reply #1 on: 13 Dec 2014, 02:23 am »
Typically someone will install a 1.5k ohm instead of a 1.5 ohm in the heater circuit.
jh
binar
« Reply #2 on: 15 Dec 2014, 09:00 pm »
Okay, I'll take a look at those resistor values, thanks!
