FS: Clearwave Resolution Six in cherry. Finest Craftsmanship! Sold
0 Members and 1 Guest are viewing this topic. Read 3379 times.
Jed
    • Clearwave Loudspeaker Design
Looking for a reference level stand mount speaker with top notch parts? Look no further. All the right details and all the right decisions were put together to offer you a speaker that extracts all the important details you're looking for, and presents it all with smoothness.
We are using the amazing sounding Seas Excel W16NX woofer that has the latest generation motor, and the cone surface area is like a 6.5" driver-- thanks to the unique basket. The transition to the ring radiator inverted Satori dome tweeter is seamless because of our phase aligned crossover technology.  We are using top quality parts in the signal path like Clarity Cap ESA, Cardas, and Supra wiring. The crossovers are hand wired for the shortest possible signal path.  Best of all, this speaker has gone through many refinements, and we built it so that each design consideration was utilized to its fullest potential. This is evident from the hand crafted curved front baffle edges for low diffraction, the point to point wiring, to the carefully selected and matched transducers.
Here's the list of features:
Seas Excel W16NX 6" woofer
Satori 1" tweeter
Low parts count crossover using the following parts:
ERSE air core inductors
Clarity Cap ESA throughout
Mundorf 10 watt resistors
Cardas soldering all point to point from binding posts to drivers
Supra wiring
Cardas copper binding posts with gold plating
Custom engraved binding post plate
Double thick 2" baffles
1" material everywhere else with vertical bracing
Flared port for low noise
Proprietary damping material to turn vibration into heat
Size: 8"W X 13.5"H X 12.25" D
Frequency Response: 42hz-25khz (43hz box tuning frequency) +/- 2.5db
Impedance: 4ohm
Minimum Power Requirements: 25watt (tube) 50watt (solid state)
Sold
http://www.clearwavespeakers.com/webapps/p/98515/300200/1236976
« Last Edit: 9 Jan 2017, 03:41 am by Jed »
