0 Members and 1 Guest are viewing this topic. Read 92451 times.
Ruben is sending the tool kit to build them as I have 10 left thumbs and no wood working tools. I can probably manage a glue up of the two 3x8" H frames
All 102lbs of the two, 3x8" flat pack and tool kit arrived today in fine condition. Made it before the rain set in!
Once the weather gets better, will be unpacking it and see if everything is ok and then start the glue-up.
Six 8" servo woofers wire and connectors are on the way.
I will be cutting a pair of 3 x 12" H frame flat packs Thursday, or Friday of this week.If anyone else would like a pair please let me know asap.Thanks,RubenThis is how they look standard, but can be modified if you'd prefer a different look.
or are you doing a triple 12" H-frame now too?
Back from travel.Here are the tools and glue for putting the 3x8" servo OB H-Frame together.Will be unpacking the flat pack soon.
-jay,Yes, they came with my flat packs, along with the glue, sand paper and straps. When Ruben said it's like putting together IKEA furniture, he gave a great description!
Ruben is "Da Man" when it comes to casework.
