If you can build IKEA furniture, these will be a breeze. H Frame Flat Packs
Outofthewoods
  • Fallen Enclosures, Inc. Crafted with Passion
Do you need one amp per woofer or one per h-frame?
1 amp per H frame. (2 woofers)
Also, the 700/pair is it for 2 h-frame (as shown in the last picture)?
Yes. $700 for 2 complete H frame flat packs.
Ruben
Outofthewoods
Hi Ruben,
Ok put me in for a pair of the 3-8" driver kits when they are ready!   :D
You got it! :thumb:
Ruben
Outofthewoods
Can't wait to get my set   :thumb:
They're headed your way. :thumb:
I just PM'ed you the tracking info.
Thanks again!
Ruben
mresseguie
Ruben,
Both email & PM sent.  :)
Outofthewoods
ctviggen
What do these look like when they're finished and where do you put the amp?  Is the amp external?
Outofthewoods
Yes, the amps are external plate style amps. http://gr-research.com/a370peq.aspx I can provide amp box flat packs as well.
This one is similar and should give you a good idea of how the flat packs will look when finished.
Ruben
ctviggen
Outofthewoods
Hi Ruben,
Shipping soon. :thumb:
Ruben
HAL
Ruben,
Excellent!   :thumb:
rollo
  • Rollo Audio Consulting -
   Way to go Rueben. Your excellent work will entice many more to make the plunge. Got me thinking now.
charles
mlundy57
How tall are those?
nrenter
Mount a wedgie on top of that (maybe on a post that rotates) and you'd have something special.
How tall are those?
I was wonderin gthe same thing,  I'm  guess it must be very clsoe  to the height of a  dual 12", possibly a  shade taller  depending on  base/top thickness.   My guess is based on   a ('x9" cavity for the  8" wooders and 3/4"  for the  2 braces.  but  maybe it's a little less ?  Even if the   driver cavities were 3.5x3.5 you'd still have 27" before to/bottom plates
How close is that Ruben ?
-jay
2bigears
 :D    holy moly ,,,, nice ,,very nice.  just the other day I brought my MAG 3.6's in the man cave to re-test.   lacked punch. of course.  but mids were great.
          I then brought in 1 of my Super-V's to back up.... just using the bottom end ,,,,  well my goodness ,, I an pretty dam happy you might say .. holy moly once more !!!!!
              will move in the other V and try multiple subs with the Maggies,,,,  :D    this is some good bass,,
2bigears
 :D   Super V's are 28" to top of bass structure ..... your right .. :D
InfernoSTi
Just to chime in on the "will OB bass work in a small room" question.  I used to have a very small room such as your room (it was a "study" and was smaller than a small bedroom).  OB bass is perfect because it doesn't load the room in the same way a sealed/ported subs do.  Make sure they are treated as "directional" though...they should face you the same way your main speakers face you.  Here is a detailed explanation:
http://www.linkwitzlab.com/rooms.htm
Not only is its bass output in proportion to the music, because room resonance contribution is greatly reduced, but also the character of the bass now sounds more like that from real musical instruments. My hypothesis is that three effects combine to produce the greater bass clarity:
1 - An open baffle, dipole speaker has a figure-of-eight radiation pattern and therefore excites fewer room modes.
2 - Its total radiated power is 4.8 dB less than that of a monopole for the same on-axis SPL. Thus the strength of the excited modes is less.
3 - A 4.8 dB difference in SPL at low frequencies is quite significant, due to the bunching of the equal loudness contours at low frequencies, and corresponds to a 10 dB difference in loudness at 1 kHz.
Thus, bass reproduced by a dipole would be less masked by the room, since a dipole excites fewer modes, and to a lesser degree, and since the perceived difference between direct sound and room contribution is magnified by a psychoacoustic effect.
The off-axis radiation behavior of a speaker determines the degree to which speaker placement and room acoustics degrade the accuracy of the perceived sound.
This means they should be great for a small room, all else the same...
John
2bigears
 :D    thanks for that info John,,,, pointed at the listener like a reg speaker was unknown to me.... will try..
           typical dual Has one sub point back and one front,, so if you want full sound,, both should point front ????  :D
InfernoSTi
We may be saying different things.  Just orient them front/back, not side/side so they face you rather than the side wall is all I was meaning.
The idea about front/back facing driver placement still applies so they would be push-pull.  Since they are open back, they still move air out the back of the driver.  The question is to decide if you want them all moving forward at the same time or one moving forward while the other moves backward. This is typical with a double H-Frame. With three, that is odd (literally)...
http://www.hifizine.com/2012/12/subwoofer-origami/
I also wanted to say these kits look really nice.  I suspect they are outstanding...
bdp24
You can mount both drivers facing the same direction if you wish, wired identically. Or you can mount one facing forward and the other to the rear, wired in opposite polarity. Either way, both drivers move in the same direction (towards or away from you; if mounted in opposite directions one from the front of it's cone, the other from it's rear) to the same signal. What you DON'T want to do is mount them in opposite directions wired identically---the output of the pair (180 degrees apart) would then cancel out each other. +1 and -1 = 0.
