If you can build IKEA furniture, these will be a breeze. H Frame Flat Packs
0 Members and 1 Guest are viewing this topic. Read 91845 times.
HAL
Will have to check as the rated DCR is 14 ohms.  That would mean the minimum is around 3.5 ohms.
Will be taking them out of the other speaker soon, so will check them with my DMM.
Danny Richie
You guys can run three of the SW-12-16FR woofers on one amp. Using the HX800 amp you can run six of them.  :thumb:
HAL
Bummer, I was going to start out with 4 per side on the A370PEQ.  Oh well, will get the three per side going first.
HAL
One more pair of the 12" OB servo subs from Danny will be here tomorrow to install in the 1x12" modules.  That will make the six to do the 1/2 stack sub tower.
Picture of the six modules built so far from the flat packs:
Guy 13
Hi HAL,
I prefer the look of the one on the right side,
but that's me
and it does not mean that the one on the left side
is not nice looking.
I'm still riveted to my computer's screen to see you next move.
Guy 13
HAL
Guy13,
The total look is all six stacked.
Ruben will make the top and bottom differently if preferred.  This was something that we talked about with the base and top just for my pair.
Two more woofers are getting here tomorrow.  Will keep building modules today and hopefully be finished by Friday.  Then load up six woofers into the towers.
HAL
The Monolith of Subs!
LOL, it looks impressive  in the pic, can't imagine how  it looks in person.
Don't have too many drinks around those....  could get a little tippy  :nono:
jay
HAL
Should not be when they are fully bolted together.  There is a lot of mass just in the MDF.  Wide base as well for stability.
Once the woofers go in at ~20lbs each, add another 120lbs.  Probably around 200lbs per side total.
corndog71
  • Some people call me Rob.
My dual ob sub weighs around 87 pounds so that times 3 = 261!
HAL
Even better!   :thumb:
gregfisk
Monolith is a perfect name for these, man would I love to here them.
Can't wait to see them finished with all 6 subs installed, way cool for sure :thumb:
So the other tower for the ribbons will be a bit shorter, thinner and stand next to these?
HAL
The line array idea is 87" tall.  Will be the offset angle "L" style baffle.  About 10" wide and 10" deep.
The line array will be in front with the sub array to the side and behind.
Baffles are being built and finished.  I can adjust the spacing of the front as needed to try different drivers until a choice is made.
Three more done.  Only three more to glue up!
SoCalWJS
Thanks for the continual updates Rich. These should sound incredible when finished!
HAL
Thanks!  Guess I am learning how to blog!   :D
Another module glued and drying.  Two more to go.
HAL
One module left to glue tomorrow.  Then start installing the 12" OB servo sub drivers.
Guy 13
Hi HAL,
yours project and the one of the daughter of Bob in St-Louis
are both captivating and I follow them daily and even more often....
Take you time, even if you are anxious to get it done,
because I enjoy every minute/step of your project.
Guy 13
HAL
Guy13,
Glad you are enjoying the pictures.
The first picture for today.  Gluing completed.  Waiting for the last module to dry and then start installing the 12" servo drivers.
Guy 13
Hi HAL,
I hope the gluing is not too messy,
because look as if you are doing it in the living room.
Did you needed wife approval to temporarely transform the living room
into a workshop ?  :lol:
Guy 13
HAL
Guy13,
That is my mom's old apartment that is attached to our house.  It was her living room.  When friends come to visit they stay there now.  All one level so easy to get around.
Time to start moving it all to the listening room downstairs for driver installation.
