If you can build IKEA furniture, these will be a breeze. H Frame Flat Packs
0 Members and 1 Guest are viewing this topic. Read 92462 times.
Outofthewoods
  • Fallen Enclosures, Inc. Crafted with Passion
H-Frames completed and ready for driver install.
All the pieces are lettered for correct assembly of the H-Frame.
Well done, Sir! :thumb:
Anything I could have done differently to make things easier on you?
Here's a pic of the modular triple 12 inch flat pack. It's not finished, just mocked up.
Unless something gets in the way I will be shipping Friday. :thumb:
Ruben
gregfisk
Ruben
So Ruben,
These are modular boxes? If so, did you do this for strength or ease of build or both?
They look really good by the way :thumb:
Outofthewoods
So Ruben,
Hey Greg,
The triple 12" towers are very heavy. This design is intended to make them easier for one person to manage. They get assembled and built out as separate units and then stacked and bolted together in their permanent location. A neat feature of this system is that you can start out with a single driver and expand as necessary.
I'll be sure to post a picture of the finished product. I've made a couple aesthetic improvements.
Ruben
bdp24
What a GREAT idea!
HAL
That should work nicely!   :thumb:
Early B.
Flat pack arrived today. Incredible packing job. Gonna spend the next few days assembling the kit and painting it. Got some Duratex to give it a textured look.
Outofthewoods
bdp24
Where's a "Like" button when ya need it?!
OH MY :o
You're out of control Ruben  :thumb:
-jay
HAL
The Audio Mad Scientist approves!  BWAHAHAHAHAHAHA!!!  :)
gregfisk
Ruben, I have 17' ceilings in my great room, how about 3 more  :thumb:
I'm sure my wife won't mind :lol:
dlparker
  • Dave Parker - KC, MO
In this instance you'd need a 'floored' button, both figuratively and literally..
Outofthewoods
I cut the fitted top to show how it looks. Not a problem for me either way. The over sized top is easier to install since you don't have to line the edges up.
Grilles will finish them off nicely!
Ruben
HAL
Ruben,
I really like the oversize top cap!  Very nice indeed!
This is very cool!
bdp24
OMG, just awesome! PM sent, Ruben.
HAL
I asked Ruben for a modular OB H-Frame sub array so that it makes it easy to ship and assemble at home.  They are setup with adjacent drivers opposing each other like the other H-Frame subs.
They will lock together for stability.
Asked Danny for a pair of the Rythmik HX800 amps to drive them as it takes one amp per side for 6 - 12" sub drivers.  The amp also has an XLR input, so I can use them with the dspMusik digital crossover as a direct feed from the DAC's since they have volume control for all 8 channels.
They are going in my 10' x 16' x 25' listening room for the system I am building.
This is going to be a fun project!   :D
Outofthewoods
Originally I misunderstood what he was asking for. Rich was asking for  2 pairs of 3 x 12" H-frames and he was going to stack and clamp together. I thought he wanted (2) 3 x 12" H-frame flat packs that he could build in steps, so after a bit of thought I came up with what you see in the pictures. Simple to build, easy to manage and expandable. Fortunately, Rich liked the looks and flexibility of the modular system better, so I didn't have to remake them as single piece 3 x 12"'s.  :thumb:
Rich, I'm finishing the grilles up today. I'll post another picture later today with the grilles attached.
Best,
Ruben
Outofthewoods
HAL
Ruben,
The grills look great on the sub array!
This is going to be very cool indeed!   :thumb:
Outofthewoods
Ruben,
Can't wait to see them once you've got them tearing your house apart at the seams. :thumb:
Ruben
