If you can build IKEA furniture, these will be a breeze. H Frame Flat Packs
0 Members and 1 Guest are viewing this topic. Read 90643 times.
Outofthewoods
  • Fallen Enclosures, Inc. Crafted with Passion
Designed to be simple, hassle free and nice to look at. Just glue it up and paint it!
All parts cut from premium 1.25" dual-refined MDF.
Pilot holes for driver screw locations.
Baffles and rear braces are drilled for wire runs.
Bottoms are drilled for spike inserts. (Danny carries the spikes)
1/2" round-over all around.
All parts labeled for easy foolproof assembly.
29"H with a footprint of 18"W x 16"D
Includes (44) 3/8" x 1.50" wood dowels, (4) 18" ratchet bar clamps, (2) ratchet straps, (1) 8 oz. bottle of Titebond wood glue and (1) sheet of 220 sand paper.
$700 pair, plus shipping.
Any questions?
Ruben
« Last Edit: 24 Jan 2015, 03:49 am by Outofthewoods »
Nice Ruben  :thumb:
Should be a popular  pack
-jay
mresseguie
O...M...G... :drool: Those look amazing.  :thumb:
If I had a room to put those in, I wouldn't hesitate.
Is that what all your flatpacks are like? How much wait time for a one-off special order?
Michael
HAL
Looks like a great kit Ruben!   :thumb:
gregfisk
This is a good idea Ruben, you're right anyone should be able to put these together, and they look great to boot :thumb:
playntheblues
  • D-Sonic, Mola Mola TamBagui, Tekton DISE
Can't wait to get my set   :thumb:
corndog71
  • Some people call me Rob.
Those look great!  :thumb:
It looks like you forgot the roundover on the woofer holes.
Outofthewoods
Michael
Hi Michael,
Shoot me a PM with what you have in mind. I'm sure I can make it very easy to assemble.
Ruben
Outofthewoods
Hey Rob,
Nope, didn't forget 'em. They aren't necessary.
I asked about the round-overs while building the Super 7's and Danny said they were not needed.
However, it's no problem to add the round-overs if requested.
Thanks for bringing it up.
Ruben
rodge827
Very nice!  :D
I'm new to OB bass and have a few questions:
What size are the drivers?
Where can I get the drivers?
What amp to use?
My room is 11'w x 15'l x 8'h will a pair work in my room or is a bigger space needed?
How low will they go?
Chris
Outofthewoods
Hi Rodge,
12" This link will take you to the product page. http://gr-research.com/sw-12-16fr.aspx
I will also be offering a similar flat pack for the 8" version of the same driver. http://gr-research.com/sw-12-08-1.aspx
What amp to use?
http://gr-research.com/a370peq.aspx
I'll let Danny chime in on this one as he can explain why OB subs perform great in smaller spaces.
Ruben
Very nice!  :D
What amp to use?
Chris
Hey Chris,
I can help yo with a few of those questions
What amp to use?
The drivers are 12"  and you can get them herehttp://gr-research.com/sw-12-16fr.aspx
Danny also has an 8 ohm version which I believe is now available that will give you   more outut.
Yu can get the amp  here:
They'll work great in your room.   My room is  just slightly bigger at  12.5x18.5  and I have been using a single  H-Frame (2 12's)   for a few months and am just finishing off the 2nd  H-frame. I have no complaints about  the single H-frame on it's own, it is  wonderful.  Clean, tight, and very  detailed, never heard bass like  it before :) The plan has always been  to have  the pair and work each one less .  No lack of output though
The servo controlled  OB 12's will play flat to 20hz  and  -3 db  in the mid teens  I beleive.
HTH
-jay
Ooops, Ruben beatme to   it   !!
Early B.
Please post your results once you have both pairs running.
I have a single W-frame (two 12's) and I'm very interested in reading about your experience with two of them, especially at moderate listening levels. My room size is nearly identical to yours.
nrenter
The 2 questions that come to mind are...
1. How much to spray a coat of paint on the pieces before shipping?
2. Does a pair of amp boxes come along with the flatpack?
HAL
Ruben,
How many 8" servo drivers will be in the next flat pack kit?
I'll update my build thread  wehn I've go tthem both up and running  <-- hopefully that will be tomorrow  8)
http://www.audiocircle.com/index.php?topic=127533.0
-jay
shadowlight
Do you need one amp per woofer or one per h-frame?  Also, the 700/pair is it for 2 h-frame (as shown in the last picture)?
Outofthewoods
Ruben,
Hey Rich,
They will come in 2 and 3 woofer configurations.
Ruben
Outofthewoods
Just shipping raw MDF.
Amp box flat packs are not included, but I can include a pair for an additional $50.
Ruben
HAL
Hi Ruben,
Ok put me in for a pair of the 3-8" driver kits when they are ready!   :D
