Holiday Special: PL Power Cable With Furutech FI-50 Plugs
DaveC113
  • ZenWaveAudio.com
The Furutech FI-50 AC plugs are the best AC plugs on the market imo, and they are on sale! I am offering them as a $225 upgrade over my standard AC plugs, for example a 4' long 14g power cable (with 11g ground wires) is currently going for $685 with the plug upgrade, the retail price of the FI-50 AC plugs is $596 so you are getting a complete cable for little more than the retail price of these plugs. My PL power cables are made with my exclusive 14g UPOCC copper litz wire, made for me by Neotech:
http://www.zenwaveaudio.com/?product=plpowercable
If you are interested email me at dave@zenwaveaudio, we are working on a way to add the option to the cart so you can checkout automatically, this should be done very soon but for now please contact me directly.
Here's some info copied and pasted from Furutech's website, with pics of a complete cable below.
FEATURES
Piezo Ceramic Series Connectors
A Furutech First!
Furutech’s Pure Transmission FI-50 Piezo Ceramic series connector bodies and housings feature several breakthrough
construction techniques. A multilayer nonmagnetic stainless steel and carbon fiber shell incorporates a special damping and insulating acetal copolymer. Furutech settled on stainless and carbon fiber for the outer housing after extensive listening sessions with Japanese industry figures and audiophiles.
The body of the connectors combines two “active” materials: Nano-sized ceramic particles and powdered carbon. (Only nano-sized ceramic particles effectively couples with carbon powder.) Nylon and fiberglass are incorporated as well forming an extremely effective, well damped, mechanically and electrically nonresonant connector body. That’s correct, they’re electrically damped as well.
Piezoelectric effects are the key. Furutech’s breakthrough in design and materials is based on employing nano-sized polycrystalline ferroelectric ceramic particles exhibiting electro-generative properties; mechanical pressure creates an electrical charge forming a bridge between electrical and mechanical oscillation.
Carbon powder exhibits thermal-conductive characteristics that interact with the charged ferro-ceramic particles converting their energy into heat that’s conducted away and released from the surface of the connector body!
These carefully chosen and tested “active” materials mechanically and electrically damp the connector and receptacle as they “interconvert” thermal, mechanical, and electrical energy for the finest Furutech Pure Transmission signal imaginable.
SPECIFICATIONS
・α (Alpha) Pure Copper Rhodium plated conductor
・Earth (Ground) Jumper System (US Patent No.: 6,669,491 )
・Nylon/fiberglass body incorporating nano sized ceramic particles for absorption of vibration resonance.
・Multi layered nonmagnetic stainless steel and carbon fiber housing and incorporating acetal copolymer.
 The best of damping and insulation materials for improvements in frequency extension and tonal quality.
・Specified for cable diameters from 6mm to 20mm
・Dimensions: Body length 44mm x 40.5mm diameter x 80.3mm overall length
・Metal cable clamp for improved grip and reduction of mechanically and electrically induced distortion.
