0 Members and 1 Guest are viewing this topic. Read 36566 times.
When switching the output impedance with the transformer, the lower impedance option will present a higher impedance load to the output tube, and should give you better bass response (because of more damping from the transformer) and lower power output. Steve uses a pretty high primary impedance on his output transformers already, so that may be why you don't really notice a difference between the settings.
Thanks Kevin, I forgot about the bias switch. My Select was in the build queue when Steve came out with the Super Zen (the basic came first), so he made mine a Super Zen Select, but with the white top without meters (the Select with black top and meters came later). Mine also doesn't have the dual inputs in the true sense of the word, or a switch, but the second set of inputs is for running it as a straight power amp. Possibly the simplest Zen Steve ever built. I believe the Zens with the UFO OPT have a switch to choose between 4 and 8 ohm, so between the input selector and impedance switch there's 2 switches where there was none before. The Basic black Zen has 3 switches: bias, impedance, and inputs.
Thanks, Kevin & Nailbunny. Now that I know what to listen for, I'll concentrate on the bass and see if I can discern a difference. Very glad to know there isn't a "right" position. After six weeks, it and the Omegas are still opening up!
After talking to Steve the other day regarding this UFO mod, the flexibility of having both 4 and 8ohm impedance on same amp was just an afterthought and a bonus. The real emphasis was on the overall sound quality and how much flatter the frequency response was and the extension on both ends. Its a much better transformer made to a much higher level of precision, thus the increase in price of the amps. Basically he not only improved on his already excellent transformers but he also managed to cram both of the Zen's 2 transformers ( stock and optional ) into one. Now the Zen amp's audio potential is not only taken up another notch but the amp itself is more flexible with different speakers. A brilliant move. Kevin
A bit late to this thread as I've only just registered! I've been using a dynamo for nearly a year now and it sounds good. I will hopefully be ordering two zen se84ckcs amps in the new year though as from what I have read they should be a step up sound wise. I will pair these with a set of super alnico monitors, I'm using dm946 speakers at the moment, though I will definetly keep those. I haven't heard a rachel so can't comment on that versus a dynamo though.
Why would you order two?
He probably wants to bridge them for more power.
I have read that but thought that each could be wired in series? Two would allow me to biamp the dm946, mono either these or my intended omega's or run the music room or tv room systems in a purist fashion. Two to me would provide more options and fun! My other half liking music I don't and vice versa would allow me to retreat to the man cave while she listens to her Bon Jovi :-pis there a real loss of transparency if run in mono? Some say yes, some say no?? Also XLR over single ended? As my main digital source has these is it worth the extra £400?? Questions, questions, though thanks for any input!!
Thanks Nailbunny, I have never gone the balanced route and the consesus of opinion seems to back you with these amps. It seems the more purist the better seems to be the way, which suits me to be honest!
