0 Members and 1 Guest are viewing this topic. Read 36605 times.
Rob,Have you heard the latest Rachael?
Hello Brianportugal,Welcome to the Omega AudioCircle. I would go for the US made Decware Rachel over the Asian made Coincident. Decware specializes in building amplifiers, but sells speakers too. Coincident specializes in speakers, but sells amplifiers too - not likely built by them
I guess I should have made the reason for my question more clear.Does your answer mean that you have not heard any Decware SE34 model?(no ulterior motive, just curious)
Coincident amplifiers are manufactured in Canada, by Coincident. That's what Coincident says, at any rate, I doubt they'd blatantly lie.
http://www.6moons.com/audioreviews2/coincident/1.html"a $1'299 Canadian-made Dynamo"
Depending on what you have, another model Decware may be a better choice.
Can you point me to where they make that claim - I can't find it on their website. You would be surprised how little actual Canadian content in the way of parts and labour can be in a product and it be legally labelled "Made in Canada". The tube amplifiers that I have preferred over the years are Decware and Ideal Innovations. They build their amplifiers on their own premises using North American sourced parts where possible. There may be some minor parts that can't be sourced in North America in which case they have to source offshore.If the Coincident Dynamo 34SE is made in Canada like an Ideal Innovations is, I'll eat my head. Once I have eaten my head, I may check into the Dynamo 34SE.....wait.....no.....that won't work. I'll eat my head after checking into the amp.
I own 3 Decware amps and I love them. You can't get more bang for the buck or a lifetime warranty anywhere.
After reading this thread I will be buying one for my soon to be delivered Super V's which are 97db efficient and should have no problem being powered by this amp according to many of the contributors to the thread.
