0 Members and 1 Guest are viewing this topic. Read 542633 times.
http://www.crownaudio.com/media/wysiwyg//XLS/XLSDrivecore_powerdraw_thermal_keh.pdfScotty
The PFC section in the XLS has reservoir capacitors that allow it to run higher peak wattage.The wattage that ranges in 200w area is on the back of the amp itself, printed next to IEC socket.Maybe I'm wrong but I'd call the heatsink insufficient for continuous 200+ watt burning. This isn't that important unless you like to run bass sine waves through your system, or the XLS would be on the cusp of enough power. I'd practice wanting some headroom with it.
OK, but I am not sure how to interpret that document. Wattage given is just the power dissipated as heat, and the only other info that isn't related to power dissipated as heat is given in amps. So I'm looking at 9.13 amps at 1/3 peak power with pink noise into 4 ohms. When run as a stereo amp. How is that info useful to me? Or how can it be made useful. Unfortunately, bridged mono data isn't given.
it's just a question of exactly how the testing is conducted.
What i'm seeing here http://www.parts-express.com/crown-xti-1002-xti-2-series-power-amplifier--245-405look at rear pic , Wall draw is 1K plus ..........................
"....These may not exactly be the power houses that they are billed to be.Scotty
Yet, according to reviews by working sound pros, they are.How about this review comment from a PA "engineer,designer, fabricator and installer":"This amp is now powering a Triple 18 sub on one side and 4 satellites on the other at 2 ohms and can ROCK a small club to pieces! The clarity is stunning and the power is endless." I've seen many similar comments in the pro audio forumsSounds pretty power house-like to me, especially considering domestic acoustic power needs!
