0 Members and 1 Guest are viewing this topic. Read 542635 times.
Unfortunately those binding posts are probably no better than the stock, maybe even worse. A lot of those direct from China binding posts are poor quality. The 'pure copper' is highly questionable especially given the price.
Yes, they are not copper, maybe plated brass, But the original binding post really are terrible. ZAK
I was trying to say that 3D depth was fine. Not a problem at all.
The Crown does a lot of things right and at a bargain price. Soundstage and overall refinement are not strengths of the XLS.
Compared to what? Don't get me wrong, I thought The Crown sounded really good, it was very quiet and powerful, but it was very flat and 2D compared to the NCore. I wish I would've had another amp to compare it to because the price disparity makes a comparison unfair. The Crown does a lot of things right and at a bargain price. Soundstage and overall refinement are not strengths of the XLS.
Luckily the Chinese posts aren't pricey, the chances they are actually pure copper seem slim to none.I had some Pomona posts in my SET amp that I've been wanting to upgrade so I put them in the Crown, it definitely seems to help sound quality and they fit with no modifications. Just make sure to get the gold plated tellurium copper Pomona posts instead of the cheaper brass ones.
Thanks rajacat and DaveC113 for the Pomona suggestion, just ordered a set for my crowns.
Where did you get your pomonas? The best deal I found is this one for 5 posts and$34.50.http://www.datacomtools.com/store/3770.htmlCryoman said to get a set of binding posts and h will cryo them so I can put them in the cryo amp.
