To hide the brightness...
So I ordered an iTube, not to raise the gain to the Crown amps, but as a tube buffer after the DAC, and to try the processing circuits. I also will try it between pre and amps, as I already have some unbalanced to balance cables made up. Guess it is the modern day X-10D (have one of those too, pretty grungy ).I didn't realize until reading the reviews (which there are quite a few out there) that the chief designer is Thorsten Loesch. Pretty cool, I've read his posts on AA for years, and he even helped me sort out some circuits in a balance cable setup I was doing, via email. He's big time now. So who here is using one of the processing circuits on their iTube and how does it help with the Crown?
Digging up more info on the iTube last night, found out the manufacturer states that using the 6dB gain setting will give more of a "tube effect" than with the no gain setting. So I guess I will be trying it between pre and the two Crown amps for sure.
Interesting. And very curious about the new iPower supply vs. Astron that folks dig so much.
You could take a piece of 19" long black plexiglass and hold it up to the rack mount ears, drill 4 holes and black zip tie it to the rack mount holes. Drill ventilation holes through some of plexi in the fan area. You can even find a Crown logo on Google Images and print it and put it on the front. Also, you guys know about Light Dims, right?http://www.ebay.ca/itm/Light-Dims-Black-Out-Edition-LightDims-/191434141108?pt=LH_DefaultDomain_0&hash=item2c925d2db4
I haven't found it listed on any iFi dealer's web sites for sale yet (Music Direct, etc.) Must be really new.
I like the iTube with the 6db gain in my system. Try it both ways. And I use the 3D setting as well. Look forward to hearing about your experience.
Crown announced that they're coming out with a new generation of these amps. Details can be found here: http://www.crownaudio.com/en/product_families/xls-drivecore-2-series
I like the new look and the new features but...Is this the same sounding amp with a few extra bells and whistles in an updated chassis?
Please report back on that one. Bold claims for that psu.
