Many thanks.The solid state dac is a Bel Canto Dac-2 and the tube dac is a Paradisea. Both have very different presentations and are kind of opposite of one another.The odd thing is the solid state dac doesn't sound quite right with the el-34 tube amp and on paper they should be wonderful together and kind of balance each other out. And on paper the tube dac should be too tooby with the tube amp. But the tube dac and tube amp play really well together.This is such an odd hobby sometimes.
Zac,If you can figure a way to get the display to turn off please pass it on. Mine looks like a bad Jr High project with black electrical tape covering most of the front and top. Looks real sexy with the lights on .Chris
I don't mind mine...
rodge827, Maybe this might help with the brightness.(Picture is brighter than it really appears). 1/8" thick tinted acrylic sheet, buff the edges, and attached with some double sided tape. ZAK
I use my iTube between a Dspeaker Antimode Dual Core 2.0 and XLS1500 with 6db gain. The Dual Core has low output and the added gain was necessary to drive the Crown and increase the range of attenuation. If possible try and get a 9v linear power supply. The improvement is seriously noticeable, I got a modded Astron SL 11A for a little over $100.00. Or iFi has since developed an upgraded wall wort power supply (iPower) for $49.00, contact the iFi distributor and order one. http://ifi-audio.com/portfolio-view/accessory-ipower/Chris
Zac thanks for the reply I will try the tinted acrylic...anything will look better that this...
Zak, any chance you can hook some of us up with those acrylic Plates? Not to handy myself...
Just wanted to say that the "tour" is officially over and thanks to all the participants who graciously took part and passed on the amp to the next party.This tour far exceeded my expectations and had way more interest than I originally thought it would incur.Thank guys for having a great time with this and keeping things cordial!-Tom
