LIO Tube Stage
0 Members and 1 Guest are viewing this topic. Read 14977 times.
radarnyc
Re: LIO Tube Stage
« Reply #20 on: 22 Feb 2015, 02:44 pm »
Vinnie, do you any sonic comparisons of the tube stage and the autoformer stage?
Vinnie - +1 on this question but maybe some sonic description of no tube stage, tube stage and AVC. Also, can you post an amatueur photo of the AVC?
Vinnie R.
Re: LIO Tube Stage
« Reply #21 on: 23 Feb 2015, 04:10 am »
Hi radarnyc and OzarkTom,
I'll try my best to get this all to you this coming week!
Vinnie
Vinnie R.
Re: LIO Tube Stage
« Reply #22 on: 24 Feb 2015, 11:55 pm »
Like this:
http://www.audiocircle.com/index.php?topic=132725.0
 :wink:
firedog
Re: LIO Tube Stage
« Reply #23 on: 6 Apr 2015, 01:12 pm »
Vinnie-
Any thought to setting up the tube stage so that it can stay "on"(warmed up), but not wear out the tube? I know some tube equipment is designed this way. I'm asking because some of us prefer to leave amplifiers on 24/7; if the tube preamp needs to be turned off to save the tubes, then we would need to also turn off our amps.
Vinnie R.
Re: LIO Tube Stage
« Reply #24 on: 6 Apr 2015, 04:22 pm »
Vinnie-
Hi firedog,
You can do this already - simply leave LIO turned ON all the time (and you can turn OFF the speaker outputs separately).
So the choice is yours  :wink:
Vinnie
