DAC-10, DAC-10H
0 Members and 1 Guest are viewing this topic. Read 78884 times.
Re: DAC-10, DAC-10H
« Reply #20 on: 30 Mar 2015, 02:44 am »
Visually the images show the DAC-10/DAC-10H as narrower than deep.
The website specifies the DAC-10/DAC-10H to be exactly the same width and depth.
Jason's above postings of the unit specifications above does not include dimensions (or weight).
Please clarify.
John Casler
Re: DAC-10, DAC-10H
« Reply #21 on: 30 Mar 2015, 02:55 am »
Please clarify.
Not totally precise since I am measuring it in the stack, in my system, and mine sits on anti-vibration feet, but:
Little over 8.5" wide x 14" deep and about 2.5" or so high.
It appears the website and manual are misprints.
Standard component widths are 17", so this is considered 1/2 width.
Very similar in size to the Reference 9 chassis. (might be taller)
rustydoglim
Re: DAC-10, DAC-10H
« Reply #22 on: 30 Mar 2015, 07:16 am »
Sorry, the correct dimension:
Height:  59 mm (2.32")
Width:   215.4 mm (8.5")
Depth:   382.6 mm (15")
rustydoglim
Re: DAC-10, DAC-10H
« Reply #23 on: 30 Mar 2015, 09:35 am »
For fixed volume at 0 db for home theater by pass:
Press and hold both buttons 3 sec to activate/deactivate Theater-Mode.
During Theater-Mode volume adjustment is disabled. Volume is set at 0 db. Headphone outputs are also disabled.
This affects all input channels.
pewe
Re: DAC-10, DAC-10H
« Reply #24 on: 31 Mar 2015, 09:17 am »
Perhaps a long shot but I have to ask: I recently sold a Slim Devices Transporter which I used together with Nuforce P8 preamp and 2 Nuforce Ref 9 V2 monoblocks an a pair of Mark &Daniel Maxiumus Monitor speakers.
I'm thinking about replacing the Transporter (and the Nuforce P8 preamp) with a DAC10 to get a "all in one preamp/DAC" and play music from my laptop. Just wondering if you think the Nuprime DAC10 is a better solution than the Transporter/Nuforce P8? Surely dac-technology must have evolved over the years but is the difference very smaill sonically?
I really like the thought of having a dac/preamp in one box.
Appreciate your thoughts.
« Last Edit: 31 Mar 2015, 12:40 pm by pewe »
John Casler
Re: DAC-10, DAC-10H
« Reply #25 on: 31 Mar 2015, 05:53 pm »
Yes, it would make a very noticeable improvement.
Primarily, due to the "much better" DAC chipset, a better volume control, a superior Power Supply, DSD and high REZ capability, and less cables and compression connections.
Even the DAC-9 would be noticeably better.
All this is assuming that your room acoustics and hearing acuity would allow you to hear the differences.   :thumb:
pewe
Re: DAC-10, DAC-10H
« Reply #26 on: 1 Apr 2015, 11:04 am »
Thank you for the answer, much appreciated.
giordy60
Re: DAC-10, DAC-10H
« Reply #27 on: 5 Apr 2015, 10:31 am »
Good morning and Happy Easter to all.
a question:
I do not find the value of the output impedance of the DAC-10 on RCA and XLR.
is really balanced?
of quele USB receiver is equipped?
thank you.
dr.sah
Re: DAC-10, DAC-10H
« Reply #28 on: 6 Apr 2015, 11:21 am »
I have DAC-10H and Nuforce ref9 V3SE. Can I put dac in standby with amps on without damadge? There is no triger in in amps. Or should i leave dac on all the time?
rustydoglim
Re: DAC-10, DAC-10H
« Reply #29 on: 7 Apr 2015, 05:32 pm »
That's fine, you can leave the DAC on and the amp off.
The recommendation for Ref 9V* amp is that the output should be connected when it is on.
Re: DAC-10, DAC-10H
« Reply #30 on: 11 Apr 2015, 01:41 pm »
What colors are the display in the silver and black models?  TIA
John Casler
Re: DAC-10, DAC-10H
« Reply #31 on: 11 Apr 2015, 04:56 pm »
The LED Display is BLUE
KLH007
Re: DAC-10, DAC-10H
« Reply #32 on: 11 Apr 2015, 06:06 pm »
IDA-16 has blue display as well.
giordy60
Re: DAC-10, DAC-10H
« Reply #33 on: 20 Apr 2015, 08:58 pm »
model in black LEDs are blue
KLH007
Re: DAC-10, DAC-10H
« Reply #34 on: 20 Apr 2015, 10:43 pm »
giordy60, What is your NuPrime sitting on (feet) ?
giordy60
Re: DAC-10, DAC-10H
« Reply #35 on: 21 Apr 2015, 06:18 pm »
is the dac 10
( is the model without headphone outputs )
KLH007
Re: DAC-10, DAC-10H
« Reply #36 on: 21 Apr 2015, 07:05 pm »
giordy60, I meant the footers, circular chrome & rubber, are they part of the DAC-10, or aftermarket?
giordy60
Re: DAC-10, DAC-10H
« Reply #37 on: 21 Apr 2015, 07:55 pm »
I'm sorry I did not understand.
are aftermarket.
KLH007
Re: DAC-10, DAC-10H
« Reply #38 on: 21 Apr 2015, 07:57 pm »
giordy60, Brand, what effect did they have, cost?
giordy60
Re: DAC-10, DAC-10H
« Reply #39 on: 21 Apr 2015, 08:19 pm »
