0 Members and 1 Guest are viewing this topic. Read 53241 times.
I suppose you know because you tried it?But does it feed the bass amp module first, then out to the upper box ( tweeter / mid range). Or does it feed from amp/speaker connections to both?
On another note...BRM, who did the metal work for the bases? When Jim built my custom sub a while back, I used a third party to build a metal base, so just curious what you did.
On a sound note, the EC amps are AUTHORITATIVE, OUT OF THE WAY, SMOOTH, CLEAR!The speakers sound 10 times better than I heard them at Axpona or RMAF. They absolutely can play with such clarity and imaging in my system it is just astounding. At the shows I would not have put these in the same league as some of the $50k+ speakers, but hearing what they can do in my system, I am thoroughly convinced they are competing with some very expensive designs. I have shaken the rafters w/o even trying and had instruments laid out in very segregated placements from left to right that I am experiencing familiar music on a new level. The "realness" of voices and instruments is spooky. I said the SS8's were different. They are different animals, but the E3's are wayyyyy better. Hands down.
Doesn't the amp need an un-amplified signal? How does that work from the binding posts?
Not to contradict you, but if you hook the sub up by LFE in and the speaker cables on these, the second the signal hits the amp, the sub will likely blow. You would have double signal coming in below the crossover point in your receiver. DO NOT DO THIS WITH EXOTICA 3s. That is all.
The result is that the amplifier signal applied to the binding posts feeds both the crossover for the midrange and tweeter as well as the speaker level input to the amp. When used in this fashion, you cannot use the line-level inputs to the woofer section at the same time. If you did, the output of your amp would be feeding the output of your preamp and disaster would likely result.
I dont have a cage on mine but others might to prevent fiddling with inputs snd settings.
I have a cage as 2.5 year olds have wandering fingers.
