Something Different...
0 Members and 1 Guest are viewing this topic. Read 8758 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: Something Different...
« Reply #20 on: 3 Dec 2014, 06:06 pm »
Hi Rick,
How come the dip starting at ~13kHz is there?
That's inherent in the response of the Morel dome. It has a fairly wide diaphragm (28mm).
Rick Craig
  • Selah Audio
« Reply #21 on: 3 Dec 2014, 06:25 pm »
Wowza! Rick, They're beautiful! How about some specs/dimensions (in one pic they look as tall as the door in back of it).
Is it time to sell my Tempestas???
KP
Graphs posted today. Sensitivity is 91.5db, 4 ohm nominal impedance, -3db @45hz and -10db @ 30hz.
TF1216
« Reply #22 on: 3 Dec 2014, 06:42 pm »
Thank you.
Rick Craig
  • Selah Audio
« Reply #23 on: 3 Dec 2014, 06:54 pm »
Thank you.
Welcome. I will say that the highs are very clean and detailed. The owner actually was quite involved with the project and  designed his own commercial speakers a few years back. The Morel tweeter was a good choice because of the small faceplate (yielding tighter driver spacing) and extended low frequency response for excellent integration with the dome mids. A ribbon would also be a good fit if more top octave extension is desired.
