0 Members and 2 Guests are viewing this topic. Read 5754 times.
A balanced Tap-x will have 4 slagleformers. I believe they cost about $900.00 each.
Hello! I am selling a TAP X on agon and got a question about the # of autoformers. The balanced units are fully balanced and have 4 slagleformers, correct? I think I mightve asked for too little money! Thanks!-- Nils
Right, I think a NEW balanced unit sells for about $2250.00 now. Wish I owned one.A balanced Tap-X with a tube amp and high efficiency loudspeakers, Oh yeah.I'd sell off all my stuff for a system like that.
I'm currently run my system that way with KT88 mono block with Quad57 ,i also run it with DAC amp with my sp tech ,that also blow my mine .But i have a hard time find the right phono stage with enought gain for the tap-x ,but that will change after a few DIY phono stage i just build. lapsan
Boozehound works fine as does the K&K that Anand built.
i just build a boozehound,i'm a little confuse regarding hooking up weed wacker battery to a charger,my lithuim battery charger have 2 post a negative and positive post.the battery have 3 post 2-positive and 1-negative post.I'm waiting for a fellow AC post some picture how to hook this up,plus i almost complete the Salas phono njfet kit just waiting for some parts from canada to arrive.
