KCS Custom Fostex F200A Speakers PRICE REDUCED ! - CONUS shipping under $99 ea.
0 Members and 2 Guests are viewing this topic. Read 2014 times.
RickRichardson
PRICE REDUCED!!! - the current price is way lower than the cost of the drivers!!!  Only $1,250!!!
I am selling a pair of KCS custom big bass reflex speakers with the Fostex F200A drivers and Hi-Vi RT2 ribbon tweeters. The rear ported cabinets were designed and built by John Kalinowski of KCS. The Fostex F200A drivers are the best sounding Fostex drivers I have heard, but are lacking at the very top end. Adding the Hi-Vi RT2 ribbon tweeters is the perfect complement being very efficient at 99 dB, and operating from 2,300 – 30,000 Hz. Mundorf Supreme caps and resistors are used for the tweeters. The results is a speaker that can be driven by low power SET amps and deliver full tight bass, clean detailed mids, and crystal clear highs. I would guess the sensitivity is in the low 90’s dB, but I can say the in a medium size room 4 watts or more makes these sing. In a small room a 45 amp works great.
These are big, good looking speakers. The bass reflex cabinets are 13” X 17” X 40”. They are quarter sawn oak with a dark stain. They are in perfect working condition, but the cabinets have a few small nicks and scratches, only noticeable from close up. One top back corner was pushed in a bit in one of the several moves they have had.
I have owned several Fostex driver based speakers over the years, including the use of limited edition drivers, such as the FE 206SE-R and the FE 203EN-S in single and double back loaded horn cabs. In my opinion, these KCS F200A speakers sound better from top to bottom. I am decommissioning the system I use these in due to downsizing, so I need to pass them on to someone else. I have had these for four years, so the 200A drivers are very well broken in, but they actually improve with use, so they will sound even better for the next owner.
Although these are higher efficiency speakers, they work well with higher power tube or SS amps. For a couple of years I used these as the Left and Right speaker in a home theater system driven by a SS receiver. When I wanted to do music, it took less than a minute to swap the speaker cables to run these on a 300B amp.
I would love to have someone pick these up in Northern San Diego County, so they don’t have to be shipped, or I could deliver them in the Southern California area for the cost of gas. I estimate the shipping size of each package to be about 48” T X 18” X 18” and 100 lbs. I know that sounds like it will be expensive, but I can ship each speaker anywhere in the CONUS for under $99 per speaker. Let me know your zipcode and I will tell you the exact amount.
« Last Edit: 29 Oct 2014, 01:28 pm by RickRichardson »
mcgsxr
What is the asking price?
srb
Why not just bump the original existing ad instead of posting a new second ad?   :scratch:
FS: KCS Custom Fostex F200A Speakers, PRICE REDUCED to $1,250, shipping < $99 ea
Thanks, Steve.  I did remove the old ad.  The last price there was $1250.
