Room Correction Systems
0 Members and 1 Guest are viewing this topic. Read 7589 times.
Pneumonic
Re: Room Correction Systems
« Reply #20 on: 27 Oct 2014, 10:56 pm »
Hi Pneumonic
Yes these MLS measuring devices will measure at about 500Hz and above and gate out the first room reflections and RTA's will measure overall frequency response (but only at one point in space). The point I am making is your ear/brain does not hear in the same way as these measuring devices.  In a real room with a real speaker you are hearing the direct sound from the speakers as well as all the reflected sound mixed in. This is called the Power Response or SOUND POWER of the speaker.
james
James, I understand that we can't use mics to measure speakers with 100% accuracy but what is the alternative? I'm not aware of any speaker manufacturer who doesn't measure their speakers performance without using a mic and appropriate testing protocols either in a room, an anechoic chamber or out doors.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #21 on: 27 Oct 2014, 11:21 pm »
Hi
Anechoic chambers and outdoor measurements and even limited gating systems --- these tools are certainly necessary and helpful in designing speakers.
All I am pointing out is that the traditional simple on axis measurement does not tell you the whole story and these EQ systems that rely on these simple measurements do not in my opinion offer the solutions or solve the problems they purport to.  The research that has been done over the past 20 years about how real speakers perform in real rooms have indicated to me that the traditional approach to speaker design has serious flaws. There are others who will disagree and thats OK but in designing the Bryston speakers I saw this traditional approach to be too myopic in concept.
james
« Last Edit: 28 Oct 2014, 01:49 am by James Tanner »
95Dyna
« Reply #22 on: 28 Oct 2014, 07:13 pm »
Hi
james
Myopia illustrated.
Grit
  • - Garrett
« Reply #23 on: 29 Oct 2014, 11:10 pm »
Hai
james
It's not uncommon, unfortunately.  I don't work anywhere near the audio industry and my work place is frequently hampered by the "we've always done it this way" concept. Without fresh perspectives and evolutionary thinking, advancement will always be limited.
- Garrett
grsimmon
  • Omni - the best way forward
« Reply #24 on: 18 Oct 2016, 02:46 am »
Sorry for waking the dead.....but I was doing some searching here on AC for comments I remember from James Tanner a couple years ago regarding digital room correction.  I'm hoping James will see this thread and give some further commentary.
So James, here's my questions:   what about not digital room correction, but analog room correction.  By that I mean,  good old fashioned, high quality tone controls,  graphic equalizers, and parametric equalizers?  I remember an article put out by Pete Thomas (?) at PMC speakers on their website about how tone controls had suffered a bad rap, and were in fact useful and justified.  That article stuck with me, and along with your stance on DSP, got me thinking recently about DSP.  I'm tempted to try DSP.  Or not. Could a parametric equalizer along with some room treatment help the average room,  while avoiding the DSP pitfalls as you mentioned?  Or do equalizers commit the same sins?
« Reply #25 on: 18 Oct 2016, 10:31 am »
HI
Sir James - Gee's looks like my status has taken a giant leap  :lol:
Anyway the problem is still there with any product that changes the 'on and off polar response' of the speaker.  Tone controls have a place I guess with really poor sounding recordings but hopefully as we improve in those areas they become less necessary.
Frequencies below 200Hz are omni directional so you can generally play around with those using Room EQ but above that frequency I would not recommend it.
james
grsimmon
« Reply #26 on: 30 Jan 2021, 09:23 pm »
James;
I just sent a personal message to your inbox regarding this thread.
« Reply #27 on: 30 Jan 2021, 09:32 pm »
James;
OK got it and sent response.
james
