0 Members and 1 Guest are viewing this topic. Read 13774 times.
Thanks for the compliments guys. Should have pics of the audio system all installed by late next week!
Yes, we plan to install some LED lighting under the cabinets. We did it on our main kitchen and love it!
Do you mind if I ask which supplier you used? I find there's everything from ordering reels of LEDs and enclosures separately, where you have to make everything yourself, or ordering kits where they've done a lot of the work for you. I was thinking something along the latter for my kitchen and some closets, but perhaps using the former for installing LEDs in my closet. But there are a lot of different suppliers, and each seems to have different sets of goods.
You might want to paint the inside walls of the closet flat black. That will help to keep the glow from all the lights from becoming a distraction.
Also, the glass I used on my rack door is "smoked". If you didn't do that, a window tint would be in order. Since your rack will be near "line of sight" from the seated position to the screen, the glow of lights, and blinking lights need to be tamed.
I see the baseboards are elevated. I assume you're putting in carpet?
I also don't see any holes drilled for the sink faucets. Surely I'm incorrect?
Almost as good as hearing the first movie.
It's funny -- as excited as I am to have new living space in the house, I'm MOST excited to hear how my audio system sounds in a new environment! lol
Carpet is in! Now we're down to the finishing touches -- install shelves for the audio rack, hang the doors, and touch up the paint.Sofas come today, then I hope to mount the TV and install the audio equipment over the weekend. Last but not least, hook up the kegerator and stock the bar!Here's a 360° view you can pan around and see the whole space: https://www.google.com/maps/views/view/114718376148802228328/gphoto/6068376750447707986
