jRiver 20
0 Members and 2 Guests are viewing this topic. Read 59705 times.
*Scotty*
Re: jRiver 20
« Reply #120 on: 21 Dec 2014, 12:57 am »
Nick, are running an ASIO driver or WASAPI? I am using ASIO4ALL with my DAC and it sounds better in the mid-range than WASAPI does.
Scotty
WIN8.1, MS-2 PC MUSIC SERVER.
richidoo
Re: jRiver 20
« Reply #121 on: 1 Jan 2015, 03:56 am »
A weird thing with JRiver that I can't figure out. I ripped some new flacs, put them in the folder that JRiver is watching. Some of the albums appeared in the JRiver library, and some didn't. I have it set to automatic monitor and I forced a scan, but they still didn't appear. Tags look OK. I think the only ones I'm not seeing are all from the same box set. Any ideas? Thanks
Happy New Year!!
Rich
Edit: I found them under Album Artist tag instead of under Artist tag. Have to make a different plan for classical music tags in JRiver.
Bear
Re: jRiver 20
« Reply #122 on: 10 Jan 2015, 07:12 pm »
What are the correct settings to enable WDM driver?  I set JRiver MC 20 as the default in the audio devices, JRiver shows lpc and it appears to be "playing" but I have no sound output to laptop speakers.  Do I need to change some settings in MC?  I running windows 8.1
lost...
Thank You
Nick77
Re: jRiver 20
« Reply #123 on: 10 Jan 2015, 07:52 pm »
I think I did the same thing and no sound, inadvertently tried clicking on regular devise in mixer and started playing hirez files thru windows as long as Jriver is playing. ??
Nick77
Re: jRiver 20
« Reply #125 on: 10 Jan 2015, 08:10 pm »
Laptop mixer at bottom of screen.
Bear
Nick77
Re: jRiver 20
« Reply #127 on: 10 Jan 2015, 08:16 pm »
Click back on your regular device system sounds, thats what worked for me. ??
"speakers and headphones" in laptop mixer.
srb
Re: jRiver 20
« Reply #128 on: 10 Jan 2015, 08:21 pm »
Disable then Enable the JRiver Media Center device.
Bear
Re: jRiver 20
« Reply #129 on: 10 Jan 2015, 09:47 pm »
I have disabled/enabled, changed settings to and fro and still can't get sound from laptop speakers using JRMC as my default device. I can get sound with Realtek set as my default of course.  Dunno what else to try.
srb
Re: jRiver 20
« Reply #130 on: 10 Jan 2015, 10:34 pm »
I am wondering why are you not seeing JRiver Media Center 20 under a Speakers device heading with a Speaker icon?  The TV screen icon is normally associated with an HDMI audio device.
I wonder if all audio playback devices are being displayed.  If you right-click on a playback device are Show Disabled Devices and Show Disconnected Devices checked?
ted_b
Re: jRiver 20
« Reply #131 on: 10 Jan 2015, 10:57 pm »
He is.  Have you tried realtek driver as your jriver device?
Bear
Re: jRiver 20
« Reply #132 on: 10 Jan 2015, 11:05 pm »
SRB, I do have those boxes checked.  Ted_b, Yes I have and still no sound.  I will try the HDMI output to my receiver as well as usb DAC tomorrow to see if I get any sound through those devices, though I am not optimistic at this point.  I must be missing something.
Bear
Re: jRiver 20
« Reply #133 on: 10 Jan 2015, 11:07 pm »
 :scratch:
Bear
Re: jRiver 20
« Reply #134 on: 10 Jan 2015, 11:18 pm »
I have tried both devices...
ted_b
Re: jRiver 20
« Reply #135 on: 10 Jan 2015, 11:18 pm »
Have you tried rebooting?
Bear
Re: jRiver 20
« Reply #136 on: 10 Jan 2015, 11:41 pm »
I have rebooted on several occasions...
Bear
Re: jRiver 20
« Reply #137 on: 11 Jan 2015, 12:30 am »
srb
Re: jRiver 20
« Reply #138 on: 11 Jan 2015, 12:39 am »
If you didn't yourself rename Speakers to "JRiver Media Center 20" and also change the icon, you can check exactly what hardware it represents by right-clicking and choosing Properties.  If in fact it is for the HDMI audio, you should see something like "HDMI Digital Jack" under Jack Information on the General Tab.
Bear
Re: jRiver 20
« Reply #139 on: 11 Jan 2015, 12:46 am »
No sir, I have not renamed anything to my knowledge.
