Well Tempered labs classic vs Well temperd Rererence
0 Members and 1 Guest are viewing this topic. Read 1728 times.
daveyonthecoast
Hello frends, it's me again!!
I have a Well Tempered classic, with Cardas re wired, steel arm, with a Marigo, brass arm clamp, for the arm cup!!
I bought, a Well Tempered Reference, that has never been used, I have not recieved it yet, as it is been sen't, from europe, as last stock from "pear audio"!!, I was listning, to a album, that I know so well, and thought Wow why did I purchase the reference, as the music, was spot on. Will the Rererence, be better, than my modify classic??
Any thought"s, when it arrives, what shall I do??, unpack it and set up, or sell it??, I't took me a long time to set up the classic, to perfection!!
What do you people think!!
David
Charisma12
Re: Well Tempered labs classic vs Well temperd Rererence
« Reply #1 on: 1 Oct 2014, 06:15 pm »
The Classic and the Reference are still great turntables. I have a Signature in my collection. But IMHO, the new designed Well Tempered Lab turntables are just better.
If you need an upgrade, you should consider the new models.
threadkiller
« Reply #2 on: 1 Oct 2014, 10:53 pm »
If it were me, knowing what I know now- which isn't much- I would sell them both and get an Amadeus. No matter what you do to those two you won't achieve the same degree of musicality. ( I had both)
