0 Members and 1 Guest are viewing this topic. Read 21522 times.
Hi Rick,Does the OEM company that produces the woofers for the Ottavo also market a 10'' version?[/quoteThis would be very interesting Ottavo configuration! Lets hope it can be done.
Is it possible to build the ottavo with one 10 inich driver as a standmount like the Eve SC3010 studio monitors ? thanks.
''What do you have in mind? Your current speakers?''Rick, actually I was looking down the road to a future 5.0 home theater/multichannel audio build, and was thinking along the lines of a modded RC5 platform with 5'' illuminators and Raal tweet as the MTM portion, and dual 10'' woofers from the same family as the Ottavo 8'' as fronts, Ottavos as currently configured but switching out the Accuton 5'' mid with a 5'' illuminator as surrounds, and a center channel using those same drivers, but in a cabinet with dimensions as close to the Magnifico as possible (due to space constraints in the rack below the TV). I know you don't see too many centers with dual 8'' drivers, but I like the idea of a center and surrounds with matching drivers. I just don't want to deal with subs, and I know this setup wouldn't require one, but it hinges on whether the company that makes the 8'' woofers in the Ottavo also have a 10'' model to accomplish a voice-matched 5.0 speaker array, and of course, whether the drivers and speaker cabinets as specified would work well in combination.
Yes we could do a custom design in that format.
Any cost in completed form or kit form for this build if available ? thank you.
I really depends on what your objectives are for bass extension and sensitivity.
possibly 35hz and 85db sensivity or more?
Thanks for the additional information. The 5" Illuminator would work well with a 10" woofer and it is possible to match the whole system.
Well if the Ottavo were to be built with 10" woofers, would it be able to extend down to the mid 20Hz range with full clean weighted bass? Or is there another Selah model that can achieve this without reinventing the wheel....Thanks!
