Other Stuff
Archived Manufacturer Circles
GIK Acoustics
French cleats
French cleats
0 Members and 1 Guest are viewing this topic. Read 1990 times.
sidders
French cleats
16 Sep 2014, 02:24 pm »
Hi.
Would it be possible to use the french cleats to install tri traps into a wall-ceiling corner? If so, could you explain how to go about that? If its not possible to use french cleats, any suggestions would be appreciated.
Thanks.
Alex Reynolds
Industry Participant
Bringing Your Sound to Life
Re: French cleats
30 Sep 2014, 06:13 am »
You mean horizontal, in the ceiling corner? No, you wouldn't want to do that. Too much stress would be pulling
away
from the wall, instead of downwards. However they can be hung up using other angled brackets. One of our customers did a pretty good install with TriTraps in the ceiling corners in his studio that you can check out here:
http://www.gikacoustics.com/client-spotlight/mike-plas/
sidders
Re: French cleats
Reply #2 on:
30 Sep 2014, 02:28 pm »
Thanks Alex. Thats great.
Other Stuff
GIK Acoustics
French cleats
