0 Members and 1 Guest are viewing this topic. Read 15522 times.
I wouldn't have thought current sales would prompt them to get the tapes back out and recut just to use a mono cutter head. While a cool idea, I'm not sure that recutting with a mono head would make a radical difference from the current reissues, which used a stereo cutter head and a mono tape machine.
Sckolnik's Beatles mono demo is largely responsible for me resurrecting my vinyl rig today, which was dormant for too long. Had to shorten four steel vertical supports for the rack, rewire custom input switch box, etc. Purchased Beatles mono late last year and hearing it at home for the first time. I would estimate these mono LPs played on a decent quality TT/arm/catridge outperforms the best digital front end, even cost no object like the dCS stack circa $100k.I suspect these mono LPs demonstrate better than any stereo Beatles source exactly why the Beatles hold their unique place in modern music history. It's interesting and remarkable how the LPs demonstrate better than stereo how great was their musicianship, especially Paul on bass. Michael Fremer did an apparently interesting A-B test, Beatles mono vs. stereo LPs at a recent show. IIRC participants unanimously agreed the mono blew away the stereo demo.I can't more highly recommend this collection.
While playing mono LP > stereo cartridge, does performance improve using one channel from the cartridge shorted to both preamp channels?
Wow, very interesting, thanks! I'm sure Sckolnik suggested, and Art Dudley echoed this in his recent Sphile article, mono cartridge performance improves using only one tone arm output channel and mono switch on the preamp. Apparently mono cartridge can have either one or two pair of output terminals. In the latter case, I don't know what is the potential difference between the two pairs of terminals, and what is the potential source of improved performance using only one pair. Probably once the former is known, the latter is self-evident. My guess is there is potential for phase difference between the output pairs, and using only one pair eliminates that potential difference.
If you take one channel and split it into two before the phono input there are impedance matching aspects that would be significant.
For mono cartridge, and stereo cartridge playing mono record, no mono switch: is L ch surface noise different and separate from R ch surface noise? If yes, mono switch of course mixes L/R ch surface noise to be identical and integrates the noise with the music between the speakers (differences in the room and L/R ear sensitivity might still introduce minor noise difference between channels).What is generally more tolerable, the former (noise separate) or the latter (noise mixed)? The former seems easier to separate noise from the music centered between the speakers, but it also has "two" noise components while the former has only one noise component.That is a great point. It applies whenever using a splitter or Y connector, such as splitting one preamp channel output to two power amp inputs. When biamping one must confirm the source has enough current to properly drive both power amps, whose load impedance is summed/lower than either amp alone. It could "work" (play music) but lack dynamics and bass punch.
