Poll
For your primary system, what does your setup consist of? (Click all that apply)
Floor Standing Speakers/Solid State Amps
19 (35.8%)
Floor Standing Speakers/Tube Amps
13 (24.5%)
Monitor/Sub Speakers with solid State Amps
4 (7.5%)
Monitor/Sub Speaker with Tube Amps
2 (3.8%)
Low Wattage with high efficency speakers
9 (17%)
Other (Explain in post)
6 (11.3%)
Total Members Voted: 53
Voting closed: 31 Oct 2014, 09:00 pm
What's your primary system setup?
0 Members and 1 Guest are viewing this topic. Read 6841 times.
Guy 13
Re: What's your primary system setup?
« Reply #20 on: 7 Sep 2014, 01:58 pm »
Hi all.
Rega Apollo CD player
Rega P3 turntable
Phono pre-amplifier (To come later Pro-Ject Phono box mm)
Rega Exact cartridge (Re-tiped by Soundsmith)
Tone arm (To come later PDR linear arm)
Decware SE-84C+ 2wpc SET amplifier
(EH6922 + EHEL84 + Sovtek 5AR4)
Bottlehead Crack headphone amplifier
(RCA 6080 + RCA 12AU7)
Audio 13 PCC (Passive control center)
Sennheiser HD-650
Sennheiser HD-570
Omega 7F extended range driver Open baffle dipole. (Discontinued)
Double inverted Eminence Acoustinator 12" woofer
in H frame open baffle dipole confirguration
driven by GR Research SA-1 ss plate amplifier (250W) (Discontinued)
PI Audio - Majik Buss line conditioner.
99% sure that this will be my last system befor I kick the bucket.
Guy 13
bacobits1
« Reply #21 on: 7 Sep 2014, 04:32 pm »
A simplified very satisfying system. All purchased used mint condition.
Pathos Classic One MKII, Hybrid Integrated, Electo Harmonix 6922/really Russian 6H23n, Gain Matched and Balanced by  J. McShane
These tubes kill all NOS I have used some $$$$ tubes.
Marantz SA15S2B Ltd
Clearaudio Emotion, CMB, Carbon Satisfy Arm
ModWright modded Monolithic Sound PS1 with custom Power Supply
Cinmag 3440A Stepup Transformer, Neotech NEI3005 wire used here.
AT OC9ML MKII, others
Usher CP6371, 91db @4ohms
All Wiring "WyWires Silver Series".
Brickwall Line Filter for the last 12 years. Don't need anything else.
Room is around 11X12 and treated with Room Tunes kit
jimdgoulding
« Reply #22 on: 7 Sep 2014, 11:17 pm »
Literally in a 12X15X8' room the fronts of my speakers are 53" off the wall behind them, 40.5" from the walls beside them and 63" apart.  My ears are typically 73" away at the end of an equilateral triangle tho I will move my chair to or fro to get the best out of an individual recording and 48" off the wall behind them which is diffused by open back record cabinets.  I get great openness and dimensionality.
I know that is not what is meant by the topic heading but believe speaker placement is critical to getting the best out of one's system particularly if you listen to a lot of recordings made on location and in real time.
You can click on the "Systems" link under my avatar for a pic and component info.
