Anyone have link to DIY power strip
0 Members and 1 Guest are viewing this topic. Read 2455 times.
Christof
« on: 2 Sep 2004, 03:33 am »
I saw a DIY power strip (box) containing 2 hospital grade recepts and twisted 12 awg FEP Teflon wire somewhere on the net but now for the life of me I cant find it....any ideas?
Thx..>Christof
Tonto Yoder
« Reply #1 on: 2 Sep 2004, 06:39 am »
Recent thread dealt with the topic, but I'm not sure it included the DIY recipe you're after.
Could THIS be a workable substitute??
Christof
« Reply #2 on: 2 Sep 2004, 01:51 pm »
Tonto Yoder
That is the exact unit I was looking for, it was in the DIY section and I was looking through the tweak page.
Thanks much!
Chris
Levi
« Reply #3 on: 2 Sep 2004, 02:01 pm »
Quote from: Tonto Yoder
That's an excellent publication! :D
JoshK
« Reply #4 on: 2 Sep 2004, 03:03 pm »
They are really pretty easy to make and can be a great product to have.  Good luck with yours and keep us posted on how it turns out.
I took the easy way out on one 'hot box'-type extention I made.  I bought the four outlet box that Hubbell makes.  It really isn't much harder to wire two outlets in an electrical box though.  There is also some info floating around on how to star ground the two outlets instead of wiring them in parrallel.
Christof
« Reply #5 on: 2 Sep 2004, 03:55 pm »
Josh did you star wire the outlets?
