Suggest a speaker
0 Members and 1 Guest are viewing this topic. Read 3895 times.
this_is_vv
Suggest a speaker
« on: 17 Aug 2014, 06:19 am »
I ahve been Diying my speaker for last two year, time has come when i just cant keep up with wife complaining all the time  of the jungle of wires behind my all active system...so i need to get a Full range passive speaker...in 2 year i have been...i know i need following...
Raal is needed , cant live without it.
Accuton or Scanspeak i can live with both for midrange....
Bass anything goes but must be fast and accurate....
any ideas which speaker i should go for....
V
mresseguie
Re: Suggest a speaker
« Reply #1 on: 17 Aug 2014, 07:02 am »
Um....budget?
this_is_vv
« Reply #2 on: 17 Aug 2014, 07:14 am »
below 8k
charmerci
« Reply #3 on: 17 Aug 2014, 07:26 am »
this_is_vv
« Reply #4 on: 17 Aug 2014, 08:14 am »
Here they are!
http://www.audiocircle.com/index.php?topic=126781.0
tx heard them at CAF was not too impressed
Also might go with quad though will miss raal highs
« Reply #5 on: 17 Aug 2014, 10:31 am »
F3 required?
How big is the room?
What are your sonic priorities (seems like detail, dynamics, imaging, emotive connection)?
Type of use (musical genres, action movies)?
What are wife's priorities (size, wires, complexity, finishes)?
Examples of speakers you like/dislike?
GT Audio Works
« Reply #6 on: 17 Aug 2014, 12:37 pm »
V
What kind of amp do you use ?
Do you need high sensitivity and high impedance ?
this_is_vv
« Reply #7 on: 17 Aug 2014, 07:32 pm »
i have ncpre nc400 and also may be soon get job 225...
music is mostly classical, jazz, indian etc
V
GT Audio Works
« Reply #8 on: 18 Aug 2014, 04:10 am »
Then I imagine with that kind of watts your speaker search will not be limited to high efficiency models.
this_is_vv
« Reply #9 on: 18 Aug 2014, 05:06 am »
I guess so...
V
S Clark
« Reply #10 on: 18 Aug 2014, 05:15 am »
Rick Craig is a talented designer and uses those drivers.  Check out Selah Audio.
« Reply #11 on: 18 Aug 2014, 11:26 am »
Seems like you're still in a DIY mindset, looking at the bits versus the whole package.  Having drivers in mind helps give some idea of your priorities, but the advantage of buying speakers (versus parts) should be gaining synergy/integration where you shop for the bottom line overall performance, so you can enjoy music not listen to drivers.  Maybe that's part of what your wife is encouraging in you.
If you really want to lose clutter, I'd look seriously at active speakers and ditch the amps, crossovers, drivers, and wires.  In your price range actives intended for home use (enjoyment versus analysis) Adam, ATC, Meridian, and PMC come to mind.
JohnR
« Reply #12 on: 18 Aug 2014, 01:48 pm »
If that is really the problem, why not a) use Speakon 8-poles for speaker wiring and b) ribbon cable for the line-level wiring? And/or put all the electronics in a single enclosure. That seems a lot less expensive and trial-and-error than chucking it all out and starting over.
Russell Dawkins
« Reply #13 on: 19 Aug 2014, 04:45 am »
Sounds to me like you might be a natural fit with Vapor Sound's various speakers. Many use the Raal HF driver.
