Purchasing a BDP, which should I get and why?
0 Members and 1 Guest are viewing this topic. Read 10902 times.
unincognito
    • bryston.com
Re: Purchasing a BDP, which should I get and why?
« Reply #60 on: 20 Aug 2014, 12:43 am »
James,
what do you mean by 'did not work out very well'??
al.
It's also pretty noisey
unincognito
    • bryston.com
« Reply #61 on: 20 Aug 2014, 12:48 am »
Chris, no problem putting an SSD in the drive enclosure?
Thankee,
Rich
________________
Whiney Napa Valley
The means — Bryston SP3 | Bryston 6B-SST(C) - L/C/R; 4B-SST(C) - surrounds; 4B-SST(C) - rears | Bryston BDP-2 Digital Player; BDA-2 D/A Converter; Oppo BDP-105 | Paradigm Reference Signature S8 fronts; C5 center; ADP surrounds; S4 rears; two Velodyne DD15 subs | APC S20 | Pioneer Elite PRO-1130
You could, but my official stance on using a ssd drive is there isn't enough performance difference to be gained for the added expense and ssd really arn't any more reliable then hard drives as both have there weak area's.  Hard drives have moving parts, ssd have there memory controllers.  Also when I say "a ssd drive doesn't have enough performance increase over a hard drive" I mean it has none when it comes to audio playback.
Cheers
Chris
gdayton
« Reply #62 on: 20 Aug 2014, 03:08 am »
maybe faster indexing, but no playback advantage.
So There
  • Brystonized
« Reply #63 on: 20 Aug 2014, 04:57 pm »
Thanks, guys. Good points on the drives.
Rich
________________
Whiney Napa Valley
werd
« Reply #64 on: 20 Aug 2014, 05:35 pm »
Cheers
Chris
Good to hear you've checked them all out!  :thumb:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #65 on: 20 Aug 2014, 06:13 pm »
Also folks I have heard from an digital engineer much more knowledgeable than myself the SSD's are a bit noisier than rotary - not mechanical noise of course but electrical noise.  Not sure if the difference would be noticeable but apparently it is there.
james
