X2 Class D Stereo Amplifier
0 Members and 1 Guest are viewing this topic. Read 19216 times.
AluminatiSound
  • Machining and Audio What A Great Match!
« on: 5 Aug 2014, 06:21 am »
Introducing The X2. Powered by Pascal’s UMAC technology for un-matched sonic performance and full power bandwidth up to 35kHz. Clean, dynamic and powerful, the X2 is World Class.
The X2 chassis is machined from 6061 aluminum. Dipping down to 2 ohms can be a problem for some, but not for the X2. It can drive 4 ohm speakers in Mono/BTL mode as well! Balanced inputs are standard and offer the best link for superior sonic performance and noise rejection. SE inputs can be used with an adaptor (not supplied). WBT binding posts with silver plated hook up wire for the best signal path to your speakers.
Specifications:
Output Power (Stereo) 250 watts@8 ohms / 500 watts@4 ohms
Output Power (Mono/BTL) 1,000 watts @8 ohms (also 4 ohms when 4ohm mono is enabled with switch)
Peak Output Current 30A
Frequency Response 5 Hz-70KHz, -3db
Input Impedance 50k ohms
THD + Noise <.05%, 20Hz-20kHz
Dynamic Range 120db
Damping Factor >1000, @1kHz
Voltage Gain 26db Stereo, 32db Mono/BTL
Input Voltage 85Vac-265Vac
Idle Power Consumption 8 watts
Amplifier Weight 21lbs
Overall size 3.75" x 11.75" x 16.25"
We offer black or silver faceplates.
Try the X2 with a 15 day in-home trial (full refund, less return shipping).
The X2 comes with a 2 year warranty.
Retail $2,499 with free shipping in the US.
On sale for $1,099!!
Please contact us if you are interested or have questions!
http://aluminatisound.com/x2-class-d-stereo-amplifier.html
aluminatisound(at)gmail(dot)com
« Last Edit: 9 Apr 2015, 04:37 am by AluminatiSound »
AluminatiSound
Re: X2 Class D Stereo Amplifier Pics/Specs/Price
« Reply #1 on: 19 Aug 2014, 06:03 am »
The owners of #0001 and #0002 are very happy with their X2's  :thumb:
Message us if you are interested!
Best,
Matt Kraemer
Tomy2Tone
« Reply #2 on: 20 Aug 2014, 01:18 am »
I would be the #2 owner of the X2 and yes I'm very happy! Very open and articulate with great bass. I have used wyred4sound sx500 monoblocks for the past few years and while they are good the X2 makes them sound dark and reserved by comparison.
I think Matt described it best as being crystal clear with great dynamics but I'll add it's a rather neutral sounding amp. It has a relatively small footprint for a stereo amp which I like and it has yet to break a sweat. It's literally almost cool to the touch which is nice living in AZ!
Matt was a pleasure to do business with and builds a quality product!
-Tom
AluminatiSound
« Reply #3 on: 21 Aug 2014, 04:46 pm »
-Tom
Hi Tom,
Thanks for the kind words and taking the time to post in our circle.
Sounds like the X2 is settling in very well :)
Best,
Matt
Randy
« Reply #4 on: 22 Aug 2014, 12:58 am »
About all I can do is echo Tom. This is a great, compact, powerful, sweet sounding amp, the best I've ever had, and over the years I've owned many of the usual suspects. The tank-like build quality is off the charts. It just oozes top-grade craftsmanship.
It came along just when I was looking for a new amp, and I feel lucky that the timing was perfect. Thanks, Matt.
AluminatiSound
« Reply #5 on: 22 Aug 2014, 05:38 am »
Hi Randy,
Your amp looks great, the blue indicator light really looks cool underneath and we are very happy that you are enjoying your new amp :)
Best,
Matt
Randy
« Reply #6 on: 23 Aug 2014, 05:11 pm »
Matt,
  Yes, it does look great, but even better, it sounds great.
  The blue glow underneath does look cool.  Strange that in my photo the badge on the front looks black, when it is silver.  Shots taken with a flash can do odd things to colors sometimes.
   I got some new/used cables to use with it, Discovery Essence. Great combo.
Randy
« Last Edit: 23 Aug 2014, 09:06 pm by Randy »
JEaton
« Reply #7 on: 23 Aug 2014, 08:54 pm »
All those photos and not a single one of an assembled unit with the cover off. Odd.
AluminatiSound
« Reply #8 on: 23 Aug 2014, 09:00 pm »
I'll be assembling two amps tomorrow and will post a picture of the inside.
Best,
Matt
AluminatiSound
« Reply #9 on: 24 Aug 2014, 10:32 pm »
Assembled two amps today and they are singing very nicely as i type this :)
You can see the divider machined directly into the case.
Best,
Matt
greenkiwi
« Reply #10 on: 23 Sep 2014, 10:23 pm »
Hey Matt,
These amps look amazing.  I love the way you've got the guts on the bottom, mounting into the unblemished top.  It looks super clean inside too.
-gk
JEaton
« Reply #11 on: 23 Sep 2014, 10:52 pm »
What does the big divider do? There's nothing on the other side of the case.
AluminatiSound
« Reply #12 on: 24 Sep 2014, 12:04 am »
It separates the AC mains from the board and input/output connections.
Best,
Matt
AluminatiSound
Re: X2 Class D Stereo Amplifier Sale!
« Reply #13 on: 5 Nov 2014, 06:43 am »
Now till the end of the year, the X2's are on sale for $1,999!!
Message us  :thumb:
Best,
Matt and Jas
AluminatiSound
Re: X2 Class D Stereo Amplifier On Sale!
« Reply #14 on: 17 Dec 2014, 04:13 am »
Lots of interest in the X2!! But remember our sale ends on New Years Eve!
Get yours now!
Best,
Matt and Jas
Occam
« Reply #15 on: 26 Mar 2015, 07:50 pm »
Do both (or either) of the mono modes,  4Ohm and normal, work when the mono input is fed a single ended signal via a RCA to XLR adapter plugged into this amp?
Thanks in advance,
Paul
AluminatiSound
« Reply #16 on: 26 Mar 2015, 11:48 pm »
Thanks in advance,
Paul
Hi Paul,
Any configuration will work with single ended inputs.
Best,
Matt
Occam
« Reply #17 on: 27 Mar 2015, 02:35 am »
Don480
« Reply #18 on: 14 May 2015, 05:26 am »
Hi, I'm new to this site.  I was wondering if you have any plans on building mono amps based off the Hypex NC1200 in the near future?  How does the NC1200 compare to ICE and Pascal?  I've owned Bel Canto Ref-500m, Wyred 4 Sound SX-1000, and D-Sonic M3-1500m. Thank you
AluminatiSound
« Reply #19 on: 14 May 2015, 05:43 am »
We don't have any plans to make an amp incorporating the NC1200. The NC400 is far superior to ICE modules, so one could assume the NC1200 would be just as good.
Best,
Matt
