Pioneer 4K/3D Receiver - $200
0 Members and 1 Guest are viewing this topic. Read 1347 times.
Dan Driscoll
« on: 4 Aug 2014, 06:03 pm »
Best Buy Link
Pioneers VSK-1023 - 980W 7.1-Ch. Network-Ready 4K Ultra HD and 3D Pass-Through A/V Home Theater Receiver
$199.99, tax in most.
mr_bill
Re: Pioneer 4K/3D Receiver - $200
« Reply #1 on: 4 Aug 2014, 06:22 pm »
Sold out
srb
« Reply #2 on: 4 Aug 2014, 06:26 pm »
That was quick, but not surprising at that price!  Should it come up on sale again .....
Pioneer doesn't refer to it as a "980W" receiver, just Best Buy and some other vendors.  The actual specs are
140W X 7  (1KHz, 1% THD @ 6 ohm)
  80W X 7  (20Hz-20KHz, .08% THD @ 8 ohm)
So I guess it could be called a "560W" receiver, which is still excellent for the price.
The "Guaranteed Speaker Impedance" is 6 ohm to 16 ohm, so if you have 4 ohm nominal speakers you may need a beefier receiver capable of driving 4 ohm loads and if you do plan to try it with 4 ohm speakers you might want see if an impedance chart is available to see if your speakers actually dip below 4 ohms at any frequency.
At this price range, there are no pre-outs except for a subwoofer (as would be expected), but if you are only going to run 5.1 and your front speakers are bi-wired, the Surround Back channels can be configured to bi-amp the front speakers which might lighten the load on the front channel amplifiers a bit.
srb
« Reply #3 on: 4 Aug 2014, 07:20 pm »
Sold out
I see that it's "Sold Out Online", so there's always a possibility that you might be able to snag one in person at a local Best Buy.
