0 Members and 1 Guest are viewing this topic. Read 67137 times.
Hello to everyone and finally will be giving US cleaning a try will be using a 10L tank and Vinyl stack for my setup and need a good starting point with the fluid.trying to keep it simple with the fluids:Distilled waterIsopropyl alcohol------how much per gallon? about 8-10 oz Triton X100------------how many drops per gallon? 6-10and a final rinse with DW and Vac dry? absolutely, more important than the fluid mixCheers
Hello, I'm on the lookout for a good, inexpensive record cleaning solution. Came across this on ebay - https://www.ebay.com/itm/Ultrasonic-Vinyl-Record-Cleaner-Cleaning-Machine-Complete-System-w-Drying-Rack/202257975166?hash=item2f1783c77e:g:AEEAAOSwwARaph2oAny thoughts on this? I would not be able to go completely DIY so thought this might be a good alternative.Cheers!
Also, I wanted to plug an U.S. Cleaner that our member Rollo is now carrying. Finally commercial cleaners are reaching reasonable prices. You can still DIY cheaper, but it's not 10X cheaper anymore.
I've gotten waaayyyy behind in cleaning... I've probably got 150 lp's that I've bought that need cleaning. So I opened some wine and got started. Got a 12-15 done.By the way, BE WARNED. These things are so much louder than you realize. Unfortunately I need hearing aids. While auditioning an "upgrade", one of the programs reached up to 50K Hz and re-interprets it down to frequencies I can hear--- and DAMN the ultrasonic cleaners are loud. Like, wear hearing protectors or leave the room when they are running, type loud. Seriously guys. These are probably too loud to safely be around when operating. My audiologist has no knowledge of the effects on ultrasonic on human hearing, but better safe than sorry. Be careful with your hearing. You can't replace it well when it's gone.
Which one?Don't leave us in the dark...
What?
T.B. no kidding around on this one. If you use an U.S. cleaner, use hearing protection. I can't spare any more frequencies lost to noise damage. I spent too many years being muzzle blasted while quail hunting with my brother... paying the price now.
Oh duh...It is the same one I recommended on this post -https://www.audiocircle.com/index.php?topic=157133.0
Here's where I landed for my US machine...Remove 51.50 ml of water from a gallon of distilled water, and replace with...Hepastat 256 - 2.00 mlTriton X - 2.25 ml97% Iso - 47.25 mlEDTA - 1 gramThis is 1/4th concentration of a scrub-n-rinse cleaning solution.
