Batman, if the question was straight up, then I'm the guy that revived this thread when Chinese ultrasonic cleaners became available cheap. The last thing I added was my experience that vacuuming the cleaning fluid reduced noise more than simply letting the records dry.
Same! Definitely interested.-Jim
You U.S. clean a record once, put it in a new sleeve and it shouldn't need it again.
I have cleaned my several times over their lives in my posession, using solution, not vacuum. Wondering now.
Batman, if the question was straight up, @SClark--which question and what does that mean, if it was straight up?
Do what works for you. For me, ultrasonic cleaning is the best way I've encountered for cleaning records. I recommend it, and now it's affordable.
What price range do you consider affordable?
They entered the market at $5k for a unit that would clean one LP. Right now you can buy a ultra sonic bath and a DIY style rotation unit that does 3-4 LPs at a time for $600. If you have an old vacuum machine for drying, even better.Buying everything brand new, you are still in for under $1K.
