BRYSTON CD PLAYER SURVEY
0 Members and 1 Guest are viewing this topic. Read 115442 times.
Jimmy71
Re: BRYSTON CD PLAYER SURVEY
« Reply #380 on: 14 Feb 2015, 08:05 pm »
At this point yes but we will do a 1/3 matching supply going forward.
No MC in this unit as I think I will do a MC section in another matching 1/3rd size.  MC should be done using quality transformers not transistors.
The New MM and MC 1/3rd size units will be the same as what is in the current BP-1.5 Phono stage
No Balanced out as it really does not improve performance in a Phono section.
james
James i have a mps-2 but can i get a 4 or 5 meter long cable to connect to the phono stage ( which you are planning)and do you think i will have any trouble if i will connect with 4 to 5 meter rca to the bp26 since no balanced to the mix? And when are your plans for the MC. Thank you
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #381 on: 14 Feb 2015, 09:09 pm »
Hi Jimmy
Do you mean a 5 meter RCA pair of cables from the Turntable?  Thats pretty long so the issue would be the PF loading of a cable that long affecting the frequency response of a MM cartridge.
james
Jimmy71
« Reply #382 on: 14 Feb 2015, 09:12 pm »
Hi Jimmy
james
No i meant from the phono stage to the bp26
« Reply #383 on: 14 Feb 2015, 09:16 pm »
OK got it  - thats no issue as the output impedance is very low so not a problem.
james
Jimmy71
« Reply #384 on: 14 Feb 2015, 09:20 pm »
james
james when do you think this unit MC will come out (aproxamite)  and will i be able to use a 5 meter plug from the mps-2 to the phono stage
« Reply #385 on: 14 Feb 2015, 09:44 pm »
The BP1.5 is available now but the other smaller units will be at least 3-4 months.
james
Jimmy71
« Reply #386 on: 14 Feb 2015, 09:48 pm »
james
No problem i can wait but will i be able to connect the mps2 to the phono stage with pin plug 4 or 5 meters because my bp 26 and the mps-2 will be 4 or 5 meters away from my turntable,that is how my setup is, and can you make that long pin plug cable.
« Reply #387 on: 14 Feb 2015, 11:07 pm »
Should be able to.
james
Jimmy71
« Reply #388 on: 19 Jun 2015, 12:47 pm »
Should be able to.
james
Hi James anything new with the phono 1/3rd? Mc phonostage?
« Reply #389 on: 19 Jun 2015, 01:08 pm »
No - we have finished the MM version but the MC version will be a matching unit going forward.
james
Jimmy71
« Reply #390 on: 19 Jun 2015, 03:33 pm »
james
when do you think will it be due?
« Reply #391 on: 19 Jun 2015, 03:35 pm »
Hi Jimmy
We have the parts in house but just not able to free up an engineer yet - be a few months.
james
Jimmy71
« Reply #392 on: 19 Jun 2015, 03:42 pm »
Hi Jimmy
james
thinking of sending my bpo26 to repair to put a mc option that is why i am asking you dont know aproximately?
Jimmy71
« Reply #393 on: 19 Jun 2015, 03:47 pm »
Hi Jimmy
james
when is the mm due for
« Reply #394 on: 19 Jun 2015, 03:50 pm »
Should be next month
james
Jimmy71
« Reply #395 on: 19 Jun 2015, 04:46 pm »
james
do you my distributors technician can put in the mc optioin in my bp26 i already have the mm option
« Reply #396 on: 19 Jun 2015, 04:58 pm »
It is a pretty delicate procedure - where are you located?
james
Jimmy71
« Reply #397 on: 19 Jun 2015, 05:00 pm »
james
greece
« Reply #398 on: 19 Jun 2015, 05:02 pm »
greece
Email Mike here at Bryston and ask his opinion.
[email protected]
We are going to be introducing an external MC stage to match the new MM stage in a 1/3rd chassis size  but it is a  couple of months out which may be a better option for you.
james
Jimmy71
« Reply #399 on: 19 Jun 2015, 06:00 pm »
[email protected]
james
that is why i am asking aproximately the month it will be out
