0 Members and 1 Guest are viewing this topic. Read 14866 times.
Haven't found a huge sound quality difference with optical cables - and had one of the very best (wireworld nova), so don't suggest you spend much there. Probably better to get a decent entry level RCA digital cable anyway. For the TT hum / fm tuning issue would suggest a shorter (1m) well shielded interconnect between TT and bellari and to have someone check the internal connections to the rca's particularly on the Rega TT. I had the fm tuning issue until I went for 2M to 1M interconnects. Also had a nasty hum and turns out the RCA connector on the TT was loose. Rega doesn't believe in spending a lot on the RCA connectors. This was the only thing I ever had fail on my Rega CD players. I've been demoing at home the VPI scout 1.1 and it's very good - the kind of table you could be happy with for the rest of your life.
Hi Guy 13, I have a VPI Scout that I’ve been using for a few years now and really like it, not to mention it’s built like a tank.While I’ve have no formal experience with Rega turntables, I would see them in audio salons years ago and think, this seems like a cheaply made turntable, for that reason along I never thought about buying one.
My simple table I'm using now addresses every single issue in build the Rega has.
Guy, I have to agree with you.I have had 3 Rega Tables. Two P3's and the last was a P5 totally blown out with $1k in upgrades purchased over 2 years.That being all the Groovtracer stuff, both platters Acrylic and Delrin. Double pulley, double White Belts, upgraded feet you can level and other things. With Power Supply and all this the table still ran fast.If you buy Rega you are buying into Gandy's philosophy. They do sound pretty good out of box.The new tables have had numerous QC issues mainly wobbly platters that Rega says are "reasonable". Read the Vinyl Engine Rega board. I know someone who has gone through 3 new P3's with platter problems and they finally gave him a P6 for a free upgrade. There have been problems with the P6 too.At any cost a platter should not wobble, PERIOD! The Tonearm wiring is still junk too. I re-wired all the tonearms with Incognito.My opinion these new tables are getting way overpriced for what they are. Buy used but check it out well or with the understanding you would be able to return it.I will not buy Rega again even a used one. My simple table I'm using now addresses every single issue in build the Rega has.The disclaimer, my opinion only and not to offend anyone.
Guy13,It is a shame that you are having such problems with the Rega TT. It reminds me of a brand that I use to own and bought three different products from. I had problems with ALL THREE. I will not mention the name. The owner was always too busy to address my problems and always downplayed my concerns, trying to assign it to noisy AC! After many, many months I sold the gear back to him at a fraction of the cost. Even though he has a good following, I think his stuff his junk and would never buy his stuff again.So I guess I feel your pain. One can never buy into the hype of a product and I think a product should be tried for a long while to see if it indeed is a good audio piece, and most importantly how does the company treat you if the audio has problems. Many audio companies just want to make the bigger sales, they do not want to fix a piece of junk they made/designed.I think AC should be a place where one can RAVE about a brand ABC, or they can honestly assess a lack of quality or follow up from a brand as well. Even if that brand has sponsorship or presence on AC. This is a forum to share info HONESTLY.
Hi Guy 13,I have never owned any Rega products so I have nothing to say or know about it. But I just thought you might be interested in this:http://www.temaadaudio.net/turntables.html
I can never understand the upgrade path on any piece of audio equipment.Example: If I want to spend 1K on a turntable and then add say, $600 worth of upgrades, even over time, why not just spend the $1600 and get a better table to begin with? Also: how long has Rega been making turntables, a wobble in the platter should be nonexistent.. If that happened to me with any company that specializes ina turntable in this case, I would be screaming from the rooftops.
