Synergistic Research Quantum Fuses, 5 and 10 amp, 5 x 20 mm fuses
0 Members and 1 Guest are viewing this topic. Read 723 times.
mikeg1
Synergistic Research 10A / 5mm x 20mm / SLOW BLOW, qty 1, $30 each plus shipping
Synergistic Research 5A / 5mm x 20mm / SLOW BLOW, qty 2, $30 each plus shipping
Sold amp and sub woofer and never used.  Includes original box.
Synergistic Research Quantum Fuses employ a custom alloy for burn wire and end caps, treated with 2,000,000 volts of electricity (with a Tesla Coil - an invention of Nikola Tesla), altering the conductor at molecular level! The body of the fuse is made from anti-resonant ceramic. SR Quantum Fuses significantly outperform other high-end fuses on the market and are guaranteed to deliver a noticeable increase in sound staging, resolution and air thanks to a lower noise floor and blacker backgrounds.
"...I replaced the HiFi-Tuning fuse with it, and it was immediately obvious how much superior it is!"
"...it seems like i have another poweramp. Much more information, smoother highs, much better defined and more tunefull low end, much bigger soundstage, more dynamics. A very serious upgrade from my HiFi-Tuning fuses and not even burned in..."
"...thought my HiFi-Tuning Supreme fuses were the best one could buy, but boy was I wrong! Within 5 minutes of swopping out the HiFi-Tuning fuse with the SR, the music became more focused, cleaner and a much wider/larger soundstage. These fuses were changed one by one and every fuse added to my system made a dramatic improvement."
"...details improved, the sound stage improved... in both my systems I obtained significant improvement in my enjoyment of the music using the Synergistic Fuses versus the Isoclean, Furutech and stock
« Last Edit: 29 Jul 2014, 05:11 pm by mikeg1 »
mikeg1
bump
mikeg1
bump
mikeg1
bump
mikeg1
Bump
