Elrog 211 tubes
jostber
Elrog 211 tubes
« on: 14 Jul 2014, 02:42 pm »
I have just got some Elrog 211 tubes for my Transcription Audio SET amp. These tubes are much wider that the GE 211s I have used in this amp until now, and so the Hal-O III-55 dampers I have for the GEs do not fit these ones. Which dampers will fit the Elrogs?
Herbie
    • Herbie's Audio Lab
Re: Elrog 211 tubes
« Reply #1 on: 14 Jul 2014, 02:50 pm »
Both UltraSonic Rx-65 and HAL-O III-65 fit the larger 211 tubes. You can most likely bend the size 55 titanium C-rings open a bit to accommodate the larger diameter, though. So long as the dampers go at least halfway around the widest part of the bulb they'll work perfectly well.
Steve Herbelin
Herbie's Audio Lab
jostber
Re: Elrog 211 tubes
« Reply #2 on: 14 Jul 2014, 03:08 pm »
Thanks! I will check out the 55 C-rings or if I have to get some larger ones.
jostber
Re: Elrog 211 tubes
« Reply #3 on: 25 Sep 2014, 04:26 pm »
FYI. The 55 dampers worked nicely here.
