Internal speaker wire
0 Members and 1 Guest are viewing this topic. Read 1122 times.
Emil
« on: 12 Jul 2014, 07:47 pm »
Hey
Anyone here experimented with different brands of internal speaker wires? What have you tried? Hear any differences? Worth the effort?
Re: Internal speaker wire
« Reply #1 on: 13 Jul 2014, 10:55 am »
Makes all the sense in the world to use the same inside and out (and should help the obsessive audiophile sleep better at night).
I've wired my single driver speakers directly from amp to each driver, but frankly didn't notice a difference.
Guy 13
« Reply #2 on: 13 Jul 2014, 11:14 am »
Hi JLM.
May I agree with you by saying:
I did the same thing as you did.
I ran my 14ga Signal Cable wire directly from my Decware SE84C+
to my Omega 7F extended range driver,
I did it that way, because I think it's a good way of doing it,
however, does it improve the sound, well ????
Anyway, I am satisfied with the sound.
Guy 13
