How to playback DSD?
0 Members and 1 Guest are viewing this topic. Read 5200 times.
haiderSonneteer
  • Managing Director and Founder at Sonneteer
    • Sonneteer, made in Britain since 1994
« on: 11 Jul 2014, 03:26 pm »
Hi Everyone,
we want to do some testing. What is the easiest way to playback DSD via USB these days? We are reaching out to the experts. Meaning you guys.
Is there a click and play method out there yet?
Haider
sonneteer.co.uk
haiderSonneteer
Re: How to playback DSD?
« Reply #1 on: 11 Jul 2014, 03:32 pm »
OOOOOh! I just read this. It does not bode well.
http://schiit.com/guides/dsd-setup
Not sure normal people will bother just yet.
Haider
sonneteer.co.uk
JohnR
« Reply #2 on: 11 Jul 2014, 04:09 pm »
Hi Haider, it's pretty simple really, just a few configuration settings. They only have to be done once.
haiderSonneteer
« Reply #3 on: 11 Jul 2014, 07:55 pm »
Thank you John,
What would you recommend as the best was to start? Are the players on the link the best options?
It is important that we use something that would not be too intimidating to the end user. I know some are willing to tackle foobar, but in terms of breaking outside of the enthusiast circle this may be a barrier.
Haider
sonneteer.co.uk
firedog
« Reply #4 on: 12 Jul 2014, 06:04 am »
JRiver MC works great. The setup for DSD is only a couple of clicks. Set and forget.
audionut44
« Reply #5 on: 12 Jul 2014, 11:59 am »
I use JRiver MC with a Schiit Audio Loki DAC and I love it.  Really, really love it.  Configuration is pretty simple and JRiver up-samples to DSD so I can use the Loki to play all my digital files regardless of format keeping everything as simple as possible.
haiderSonneteer
« Reply #6 on: 12 Jul 2014, 01:48 pm »
Thank you guys. That is very helpful. A little more confident now diving in.
Will report back. Also if anyone has any other way of doing this we would certainly be interested. Always learning here.
Haider
sonneteer.co.uk
haiderSonneteer
« Reply #7 on: 12 Jul 2014, 06:48 pm »
Also has anyone tried DSD via a network yet?
I imagine this is the long term future of playback. Network, online or otherwise I mean. Formats will forever be nomadic.
Haider
sonneteer.co.uk
firedog
« Reply #8 on: 13 Jul 2014, 06:49 am »
Yes, it works fine, even on wireless, as long as your network works okay.
Haider
sonneteer.co.uk
Rabbani
« Reply #9 on: 13 Jul 2014, 08:55 am »
Thanks All. I am new in downloading JRiver Player to my MBP. Can you all explain How to up sample using JRiver from 16/44 to DSD? Appreciated you reply with screen short.
Rabbani
haiderSonneteer
« Reply #10 on: 15 Jul 2014, 12:21 pm »
Good to know. What exactly is your set up? Would certainly help to know and understand how it's done.
Haider
sonneteer.co.uk
haiderSonneteer
« Reply #11 on: 15 Jul 2014, 12:23 pm »
Rabbani
JRiver need to pay us commission as that's two of us off here now, new. 8)
Haider
sonneteer.co.uk
ted_b
« Reply #12 on: 15 Jul 2014, 12:52 pm »
I developed two 20 minute screencast videos on setting up JRiver for audiophiles.  It includes tips and techniques, mass tagging, DSD setup, etc.  Feel free to download.
http://www.audiocircle.com/index.php?topic=121419.0
Big Red Machine
« Reply #13 on: 15 Jul 2014, 01:03 pm »
Like the videos Ted.  Can you make one on how to combine libraries for those of us stupid enough to have set up mutliple libraries?!
haiderSonneteer
« Reply #14 on: 15 Jul 2014, 01:11 pm »
Thank you very much for this. Useful for all it seems.
Haider
sonneteer.co.uk
Big Red Machine
« Reply #15 on: 15 Jul 2014, 02:26 pm »
I run my Chord dac easily and play all files natively.  I can tell the fidelity by the colored lights.  Would I be better served by having everything upsampled to DSD?  I think there are two sets of clicks to make that happen.
firedog
« Reply #16 on: 15 Jul 2014, 08:59 pm »
You just have to try it and see. Some like it better, others don't.
haiderSonneteer
« Reply #17 on: 16 Jul 2014, 08:35 am »
Thanks for all of this. Do we think that DSD has hope of hitting the mainstream? (pardon the pseudo pun) What would be needed for it to do so?
Also  did I miss it or was there an explanation of how to best stream DSD via network?
Haider
sonneteer.co.uk
JohnR
« Reply #18 on: 22 Jul 2014, 09:18 am »
Hi Haider, I suppose it depends on what you consider "mainstream". Reports comparing PCM with DSD do seem to consistently favor the latter. I was actually a bit surprised in a short check that I could hear any difference at all, but there you go! However, what proportion of the population care? We're all nutter audiophiles here....
