Vr-6 specs
0 Members and 1 Guest are viewing this topic. Read 1486 times.
illenema
Vr-6 specs
« on: 30 Jun 2014, 04:39 pm »
Anybody have the specs on these? weights size ect.
I had the big brother (vr-8)  looking to down size due to room size
JackD201
Re: Vr-6 specs
« Reply #1 on: 1 Jul 2014, 02:28 am »
Try PMing the member here with username wolfsongaudio. He had a pair for sale.
You can also try e-mailing VSA. They might have migrated the VSR era URLs to the new site even if links are not provided. They could provide you with either the URL or email you the actual manual .DOC
Good luck!
In the meanntime here's what I dug up, I couldn't find any dimensions, sorry :(
Weight 175lbs  per side
Sensitivity 96dB
Drivers
2 - 9" Cast Eaton woofers
2 - 5.25" woven carbon fibre Audax midrange drivers
2 - focal titainium tweeters. One is rear fired for ambiance control.
illenema
Re: Vr-6 specs
« Reply #2 on: 1 Jul 2014, 05:54 am »
Yes thanks for reply, like i said had the vr-8 that were giant. And were very interesting speakers used a number of great amps solid and tube and brought out the best in everything that was hooked up to them, and stayed out of the way sonically, Just was looking for shipping info as the tops are exactly the same- separating veneer and all :)
JackD201
Re: Vr-6 specs
« Reply #3 on: 1 Jul 2014, 05:35 pm »
Wolfsong wrote 3 boxes 400lbs total. No dimensions for the boxes. I'm guessing one box for the pair of MT modules and a box each for the bass modules.
