Too much of a good thing?
0 Members and 1 Guest are viewing this topic. Read 1961 times.
Karnaaj
« on: 28 Aug 2004, 12:33 am »
Hi everyone.   What I am trying to figure out is how much power I need for my fairly small listening room (12x15).   Living in an apartment I can't have the volume up high, besides the fact that I tend to enjoy listening at moderate levels anyway.   My question is given the room size and my personal preferences is there any benefit at all in getting a 200w amp or greater integrated?   At any given decibel level will a higher powered amp sound better than a lower powered one, or is the benefit only apparent a higher volumes?   All replies will be greatly appreciated.
eico1
« Reply #1 on: 28 Aug 2004, 12:53 am »
That would depend more on speaker load and efficeincy than room size.
As far as amp design goes, an amp with a single pair of output devices shoud be better sonics for the money and those amps are usually rated 70-100W.
steve
Hantra
« Reply #2 on: 28 Aug 2004, 01:14 am »
Karn:
I have been through this as well.  I have a 12.5 x 14.5' room, and I have run the gambit from 18 watts, all the way to 600 watts.  I am happiest with 300+.  Right now, I have an amp that is 360 into 4 ohms, and it's extremely more powerful sounding than the 125 Class A watts that it replaces.
I haven't been satisfied with less than 300.  For me, that means the Plinius integrated, which I had, and the Perreaux integrated, which I have now are the only amps that have satisfied.
Then again.  Like Steve says, it ALL depends on your speakers.  Who would have thought one would need at least 300 watts in such a small room!?
HTH,
B
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #3 on: 28 Aug 2004, 02:38 am »
Hantra,
What are your speakers rated sensitivity?
« Reply #4 on: 28 Aug 2004, 11:42 am »
Funny how this question comes up all the time, as it's similar to asking, "How big of an engine do I need in my car".  You could probably get by with a 50 hp engine in a 3,000 lb car, but it'd take 2 miles just reach 70 mph and that would be it's limit.  If you wanted any kind of thrill of driving you'd probably start looking at 200 hp engines and bigger.
Math time:
Speaker efficiency is rated by sound pressure (dB) output per watt input at one meter in front of the speaker.  Typical speakers run about 85 - 92 dB/w/m, but can range from 80 to 109 dB/w/m.  These ratings are based on having no room reflectance.  Note that one dB is the smallest difference in sound pressure (loudness/volume) that the average person can perceive.  Conversational sound pressure levels run around 60 dB, most audiophiles listen at roughly 85 dB, symphonic concert peaks are 105 dB, rock concert peaks run up to maybe 110 dB.  Keep in mind that these are peaks.  Sound pressures for rock doesn't vary nearly as much as other musical forms, especially classical.
Smaller rooms provide more reflectance than larger ones, partly because you're forced to sit closer to the speakers.  Rough rule of thumb is that a 2,000 cubic foot room (say 12 ft x 20 ft x 8 ft) with two speakers will result in acheiving the rated speaker efficiency (room loss = gain from using two speakers).  From your room description you may see a 1 or 2 dB net gain.
The relationship between speaker sound pressure output and power input is logrythmic.  So a 3 dB gain in volume (sounds half again as loud) requires twice the power and a 10 dB gain (sounds twice as loud) requires ten times the power.  Since speakers are rated at one watt input 1 watt = 0 dB of gain.  Examples (using two speakers in a 2,000 cu. ft. room):
85 dB efficiency speakers with 100 wpc amp = 85 + 20 = 105 dB
90 dB efficiency speakers with 40 wpc amp = 90 + 16 = 106 dB
95 dB efficiency speakers with 10 wpc amp = 95 + 10 = 105 dB
If you're a rocker:
85 dB speakers need a 400 wpc (26 dB gain) amp
90 dB speakers need a 100 wpc (20 dB gain) amp
95 dB speakers need a 40 wpc (16 dB gain) amp
You can see why P.A. speakers must be highly efficient as bigger rooms would otherwise require even more power.  IMO high quality stereo amps start at $500 for 2 wpc, but quickly get much more expensive with $2,000 for 150 wpc being common.  Some of the new digital amp technology based receivers are the exception to the quality versus power versus cost paradigm ($200 can get 100 wpc for 5.1 systems).
Important:  Speakers can handle excessive amounts of un-distorted power much easier than lesser amounts of distortion.  This is because as amps are asked to exceed their rated output the nice smooth waveforms that music represents get flattened off at the peaks (this is called "clipping").  Not so bad for the amp, but the speaker is simply trying ot follow the signal fed to it by the amp and instead of smoothly following musical forms each driver is being asked to stop and start instantly.  This results in energy being delivered and it has no place to go, so the extra energy is released as heat that melts the drivers voice coils.
But you say, I don't plan on listening at levels of 100 dB or more.  Well, peaks "sneek" up on you pretty easily.  And IMO you want to size the amp to be able to keep a very good grip on the speaker and bully them around a bit, similar to sizing the engine in a car.  So I'd recommend sizing the amp to at least reach the peaks mentioned above.  (Always check to may sure the speakers are rated to handle that much power.)
Hantra
« Reply #5 on: 28 Aug 2004, 02:25 pm »
Quote from: heavystarch
Hantra,
Well, they are rated at 89db.  I can say without a doubt that this is BS.  Stereophile measured the C8 Limited at 86db, and they have an extra woofer.  So, I am assuming mine are 84-85db.
Karnaaj
« Reply #6 on: 31 Aug 2004, 01:14 am »
Thanks for all the replies guys.  I was starting to think that 100w would be enough, but I believe now I will go with at least 200w maybe more. :o
PhilNYC
« Reply #7 on: 31 Aug 2004, 01:30 am »
I thought volume was a function of voltage gain, not wattage...?
