Free DSD64, DSD128 and DSD256 session tracks (stereo, multichannel and binaural)
ted_b
Looks like your Zhalou (probably 2.5?) is most resolving, but use whichever you like best, then convert the DSD files to the sample rate that DAC sounds best in.
hdspeakerman
How do I make that conversion?
ted_b
As I said a post earlier, JRiver will work.  If you don't have it, there is a 30 day free trial.  There are other players and software to convert too (do a search on audiventory here for his converter).
http://www.audiocircle.com/index.php?topic=128720.0
In JRiver simply load your DSD files, then highlight them, right click, library tools -> convert format.  The rest is pretty intuitive ("convert files to" has a pulldown selector, check options, etc).
hdspeakerman
Ted,
Thank you for your help and patience.  I got JRiver to work and I am enjoying some of the material I downloaded.  I never could get the other program to work for me.  I guess I will play will JRiver for the next 30 days and then worry about the other one.
Howard
