0 Members and 1 Guest are viewing this topic. Read 4853 times.
In the meantime, I picked up one of those pioneer 912s. Definitely within my budget! I'll probably just try it for the preamp section, but I'm not sure if it will fit in my space...Recs still welcome.
Thanks for the recs.All them shorted rca plugs...are you sure it's still C&C after that??
Can't one make rca shorting plugs by taking the interconnect that come with CD, DVD players, etc. cutting them a couple of inches from the plugs, twisting then taping the inner and outer wires together.If necessary you should be able to find cheap interconnects at the dollar store.
Where does one get cheap RCA plug for a few cents each? I have a few friends that need a bunch.
