0 Members and 1 Guest are viewing this topic. Read 7907 times.
You won't see those designs out of Dejan the tube hater Hey Dejan, what I would like to see is what we talked about years ago. A pre-amp that contained it's very own crossover(s). Variable slopes, variable crossover points, variable gain for each band and last but not least a remote control that allows gain control for each band (for us lazyphiles). You could make them in bi and tri amped versions. Something absolutely unique to the market.For the money Marchl ...
I wouldn't mind seeing an amp kit for more than 2 channels (like say... 7 channels ) that doesn't cost a small fortune.Would also be good if it wasn't a space heater for a small airpane hanger.
The 7 channels I'd be looking for aren't for bi-amping. I run a 7 speaker setup, w/2 subs. Luckily the subs are powered. Finding 9 channel amps is a lot harder than finding 7 channel amps... Sure, monoblocks can be good. But that'd not only take up a lot of room (a 7 mono stack would be rather tall), but it'd take up a whole lot of power cords & outlet space. And I'm sure that mono's would be ultimately better sounding if taken to the extreme over a big MC amp.But sometimes a little bit of con ...
Dejan,I understand not wanting to get to the transport or DAC, but my suggestion was simply to illustrate what I think the DIY community needs as opposed to wants. I am sure an amp kit from you would kick ass.
Thanks Dejan. I have yet to play around enough with digital (actually not at all really) to know what can be done via tweaking. You are probably right. When I get around to tweaking my Sony XA777, I'll bounce my ideas off you if you don't mind.
It's incredulous to me people are willing to invest so much into cables and swapping components rather than a smooth eq as you describe. All the detail, soundstage, whatever else etc. desired would be at their fingertips.What isn't understood is that eq corrects the source, not crappy equipment or rooms as the audio mythologists would have us believe and fear.
Build up the kit, just don't forget the Quad Tilt control! It may just create a whole new movement, it will be just like the 60's:).steve
Dejan,To clarify, I was mostly responding to Rob's comments and I agree that amp/preamp kits can be different because of the complexity and higher learning curve. Kits here can be different, but I really like your ideas on how to offer it. It lets DIYers at different points in the learning curve attempt it at a level they feel comfortable while allowing experienced guys have more flexibility and minimal starting point.
