SOLD : Jolida 502A Integrated Amp - $500 OBO - BARGAIN!
0 Members and 1 Guest are viewing this topic. Read 1271 times.
jarcher
  • It Just Sounds Right
SOLD
This is an excellent modern sounding integrated tube amp in great condition for an unbeatable price.  Last Ebay sale was at $700 and current Ebay asking price is $680.  A new 502B retails for $1,600 and functionally is very much the same with the exception of the remote control function and auto biasing for the tubes.  So at $500 this amp is a steal!
The fundamentals of this amp are quite good, in particular the german steel transformers and the circuit board with it's large traces.  Many people buy these to modify and upgrade, turning them into great amp only.  This one has not been modified / upgraded as far as I am aware other than a factory addition of variable RCA preamp outputs, which are quite handy for either a subwoofer, or to do bi-amplification.  The previous owner used this to drive the mid range / tweeter of his speakers and a solid state amp for bass drivers.  Nonetheless this amp has plenty of power to drive even demanding loads, and the flexibility to use 6550, KT88, KT90 and even KT120 tubes.  I think the KT120s I tried sounded best, but currently it's configured with Electroharmonix KT88's.
I've been using it recently and it is in excellent operating condition.  Cosmetically the only noticeable condition is a scratch on the back of one output transformer (see photos).  In many ways I prefer this "back in black" look w/ visible transformers to the later silver Jolida 502B's with their transformer cover.  I'm selling because with three other tube amps in the household, it's just not getting the use it should and could use a new home.
Will ship in it's original box at actual postage value, most likely via Fedex ground / home delivery.  Sales within the USA highly preferred.
Payment via Paypal preferred and free if sent "friends / family" where no commission is charged. Other forms of payment are accepted.
Any other questions, please feel free to ask.
SPECIFICATIONS :
MAXIMUM POWER OUTPUT: 85 W PER CHANNEL AT 8 OHMS. 1 KHz
RATED OUTPUT POWER: 60 W PER CHANNEL AT 8 OHMS, 25 Hz TO 60 KHz
FREQUENCY RESPONSE @ 1 WATT INTO 8 OHMS: 8 Hz TO 130 KHz +/- 1 dB
BANDWIDTH: 15 Hz TO 80 KHz +/- 3 dB; 0 dB 60 w 1 KHz
DISTORTION THD: LESS THAN 1% @ 20 V OUTPUT, 28 Hz TO 15 KHz
CIRCUIT TYPE: ULTRA LINEAR, CLASS AB
INPUT IMPEDANCE: 100 Kohms
INPUT SENSITIVITY: 600 mV AT 1 KHz FOR 60 WATT OUTPUT
OUTPUT IMPEDANCE: 4 ohms AND 8 ohms
NEGATIVE FEEDBACK: LESS THAN 5 dB
NOISE AND HUM: 85 dB BELOW RATED OUTPUT
TUBE COMPLEMENT: TWO MATCHED PAIRS OF 6550/KT88 POWER OUTPUT; 2 PCS 6DJ8/6922 PREAMPLIFIER; 2 PCS 12AT7 POWER DRIVERS
DIMENSIONS: 16.375" X 12.5" (excluding knobs & speaker jacks) X 7.5"
WEIGHT: 40 LBS, 50 LBS PACKED
BIAS SETTINGS: 50 mV +/- 5 mV (I always set bias at 45 mv)
FUSE: 110-120 VAC, 5 FAST AMP BLO; 200-240 VAC, 3 AMP FAST BLO
« Last Edit: 5 Jun 2014, 05:10 pm by jarcher »
