Something new that sounds incredible
mikeeastman
Re: Something new that sounds incredible
« Reply #680 on: 22 Apr 2016, 03:38 pm »
Danny, what would be a good distance to separate x-over and sub amp? I have 15" now.
Danny Richie
« Reply #681 on: 22 Apr 2016, 03:40 pm »
That should be fine.
Keithh
« Reply #682 on: 22 Apr 2016, 04:13 pm »
That is a different crossover than what my Wedge has. The reason I am asking is that I want to try foil inductors that are quite
a bit bigger than the standard Erse coils which already block some of the bottom driver.
Danny Richie
« Reply #683 on: 22 Apr 2016, 04:31 pm »
Yeah, that is the crossover for the new NX-Otica.
I stock the foil inductors also. The same size foil inductor is actually a little smaller in diameter then the Erse XQ. So size limitations are not an issue.
Here is the Wedgie crossover.
Even if the crossover is pushed up pretty close to the drivers it still shouldn't cause any blockage issue.
