Something new that sounds incredible
0 Members and 3 Guests are viewing this topic. Read 274437 times.
baniels
Re: Something new that sounds incredible
« Reply #340 on: 10 Sep 2014, 08:16 pm »
Yes, I will be. Keeps the shipping cost down.
Danny Richie
« Reply #341 on: 10 Sep 2014, 08:31 pm »
Will Ben be shipping the flat packs direct?
Ben will be drop shipping the flat packs directly, and then he sends me a bill for it. So it makes it real easy for the customer.
And he beat me to respond...
mlundy57
« Reply #342 on: 10 Sep 2014, 08:31 pm »
That makes sense
mlundy57
« Reply #343 on: 10 Sep 2014, 08:34 pm »
Are you ready to start shipping these?
mlundy57
« Reply #344 on: 10 Sep 2014, 08:38 pm »
There is just one cap in the tweeter circuit. So to by-pass it with a Platinum is only $36 per speaker. Yeah, that would be worth it.
I think Jay is asking about the caps needed for the inline filter.  At one time you mentioned you were really low on certain values.
For me I would need caps for an amp with 100 ohm input impedance.
Danny Richie
« Reply #345 on: 10 Sep 2014, 08:53 pm »
Taking orders now and putting kits together. I have several to ship already.
Better be cutting wood over there Ben...
baniels
« Reply #346 on: 10 Sep 2014, 08:56 pm »
Making dust tonight :)
mlundy57
« Reply #347 on: 10 Sep 2014, 09:04 pm »
I'll call you tomorrow to place my order. I take it NoRez isn't useful with these speakers, correct?
Danny Richie
« Reply #348 on: 10 Sep 2014, 09:09 pm »
I need to play with a piece on the side panel, but I think the effect will be minimal.
« Reply #349 on: 10 Sep 2014, 09:20 pm »
Nope, I was talking  about using  to bypass the  reg sonicap inthe   high pass (tweeter) circuit on the cross over.
Sorry,  made a mistake  with regards to the inline  filter, deleted
-jay
mlundy57
« Reply #350 on: 12 Sep 2014, 10:56 pm »
-jay
Sorry Jay, I mistook "high pass filter" for "in-line filter"
Mike
mlundy57
« Reply #351 on: 12 Sep 2014, 10:59 pm »
OK my Wedige (is that the official name?) kit is on order as well as the caps for the in-line filter.
The niece and nephew may have to take a back seat for a little while. When the Wedgie gets here I'm starting in on it.
Mike
« Reply #352 on: 13 Sep 2014, 12:03 am »
Mike
Awesome Mike, can't wait to see the build, that gos for the rest of you guys  who've ordered them too  :lol:
Did you also order the  parts for the H/U-frames to build  your  bass section  or are you  using something else to get by with , those dual 8" subs you were working on a while ago perhaps ?
-jay
Rocket_Ronny
    • ScriptureSongs.com
« Reply #353 on: 13 Sep 2014, 12:05 am »
Maybe I missed it, but what solution did you come up with regarding the mid bass to sub frequencies.
Ron
mlundy57
« Reply #354 on: 13 Sep 2014, 01:29 am »
-jay
Jay,
To start with I'll be using a single Von Schweikert VR-S1 sub. This is a sealed sub with a single 10" servo controlled driver.
As soon as I can I'll be building 2 of the ported dual 8" non-servo subs I was working on awhile back.  I already have the drivers and amps, just need the wood and time.  These will have to wait until I get all my other projects finished though.
Then, when I can afford them I will build 2 of the dual driver H frame OB subs.  I'm still not sure whether I want to use the 8" or 12" drivers. I understand the 12" drivers would be the best sound but I don't know by how much or why.
Another concern is whether the 12" drivers would be overkill in a 1,144 cu ft (11'x13'x8') room.
With the 12" drivers, an H frame looks like it would put the center of the tweeter at 41". That is 2-3 inches too tall if I want the center of the tweeter at ear height. A W frame would lower the tweeter height.
I don't know what the performance differences are between H frames and W frames. Can anybody enlighten me on this?
Mike
ebag4
« Reply #355 on: 13 Sep 2014, 02:24 am »
Mike, I run two pair of the 12" servo subs in my 10.5.'x12.5'x8' room and they are not overkill, they sound fantastic with no boom and I have great bass below 20Hz:
I had a choice of a suckout at 60Hz or what you see, I chose the later.  What I can't tell you is how the 8" servo subs would do, but the 12's are outstanding bass, best I have heard.  I also have a 4 AE IB15 drivers in an infinite baffle alignment in my HT driven by 2400 watt Behringer amp, I prefer the servos for music.
mlundy57
« Reply #356 on: 13 Sep 2014, 02:37 am »
Thanks, that's good to know.
Mike
Danny Richie
« Reply #357 on: 13 Sep 2014, 02:55 am »
Mike, they won't overpower the room unless you want them to.
There are advantages and disadvantages to the W frame. The advantage is that it is shorter. The disadvantage is that they have a larger un-braced panel area. So they are more prone to a resonance of the side panels.
mlundy57
« Reply #358 on: 13 Sep 2014, 04:32 am »
Would it be better to have the tweeter a little high and go with the better braced H Frame?
Maybe elevate the rear of the Wedgie a little to point the tweeter back down?
bdp24
« Reply #359 on: 14 Sep 2014, 11:14 pm »
If you want the shorter height of the W-frame, you can run a horizontal brace (3/4" X 3", say) across the driver openings, from the inside of the left panel to the right. That will minimize the resonance of those panels about as well as they are in an H-frame.
