FS: Rythmik Audio A370PEQ amp in Darrel Hawthorne maple box
0 Members and 1 Guest are viewing this topic. Read 2742 times.
gab
Up for sale is one (1) non-servo version of the A370PEQ with a 6db/octave compensation circuit for use with open baffle drivers. This is the version that Hawthorne Audio used to sell for use with their OB drivers. The new price on the amp was $379 and the maple box it resides in was $165. Here is a link showing the amp and box: http://www.hawthorneaudio.us/catalogs/index.php?main_page=product_info&cPath=4&products_id=49&zenid=8jpjc0qdbakp64mmjaj124apb2
This amp can also be easily converted to a servo version for use with Danny's servo drivers for $30 (I can forward Brian Ding's email to you for the details). I am the second owner (but I never got around to using it or even powering it up). It was bought from another AC user who was the original owner and he used it with his Augies.
$250 plus shipping in US (or pickup in Dallas)
Audiogon feedback under “gabster”
Gdurrant
Re: FS: Rythmik Audio A370PEQ amp in Darrel Hawthorne maple box
« Reply #1 on: 9 Oct 2014, 01:07 am »
Hi there, I know that this has been posted for a while - is it still available ? Is it in full working order and  how many ohms is it?
gab
« Reply #2 on: 12 Oct 2014, 08:24 pm »
Sorry - just now saw this. Yeah still avail and I really don't have a good use for it unfortunately. Yes full working order. Specs on the amp are here:
http://gr-research.com/a370peq.aspx
gab
mlundy57
« Reply #3 on: 12 Oct 2014, 08:34 pm »
I have a question. I just noticed that your description says a non-servo version but the picture says Direct Servo on the amp. So is it a direct servo or not?
Also, does it have the open baffle circuit or is it for use with a ported or sealed box?
Mike
gab
« Reply #4 on: 12 Oct 2014, 08:47 pm »
Mike
As I understand it after communicating with Brian Ding (owner of Rythmik Audio), Rythmik takes a basic amp module that they had developed for them and then they add various boards for different manufacturers. So there is a direct servo version like Danny sells here and for Hawthorne Audio, he did an open baffle version for use with the Augie OB drivers that he sells. This latter version is what I have. ALL OF THESE VERSION LOOK THE SAME FROM THE OUTSIDE AND THERE IS NO DIFFERING PART NUMBERS TO IDENTIFY WHICH IS WHICH. I shouted because I think this is very poor engineering discipline (think GM ignition switch issue) but whatever.....
Brian told me he can convert this "open baffle" version to a "servo version" for about $30. Likewise it can be converted for use as a sealed or ported version (no Linkwitz transform circuit as in the open baffle version and no servo version) by removal of a capacitor. I would recommend that Brian and Rythmik do this, but I suppose if you are good with electronics, Brian could walk you through it without a trip back to the factory in Austin Tx.
Danny and/or Darrel Hawthorne may be better able to describe this than me or better yet, Brian Ding. But any of the three versions will all look the same from the outside - you have to know what modules Brian put in it to know what it does.
Hope this answers the question. Don't want anyone confused! It would have been so much easier to change the part number or put a sticker somewhere or...OK done
gab
EDIT: here is link to Hawthorne Audio site to show the Rythmik in Darrel's wood box. Blow it up and it looks like it is a "direct servo" version, but it is not!
